So I built a gaming PC and recently it's been completely freezing. Only when gaming does this happen and it doesn't loop audio. Just the last frame from the game freezes and I can't do anything. I have to hard reset and up until the game freezes I have zero performance issues. Sometimes it freezes and I still have audio and the game starts working again. But the rest if the time the games run like butter. I know there are a hundred threads on this but none of them have helped. At first I thought it was my psu so I bought a new quality one. Didn't fix it. I bought a new ssd and used Samsung's software to move everything over to it. That didn't fix it. I borrowed a couple sticks of a friend's ram and checked the ram configuration. That didn't fix it. I tested my 660 in another friend's pc with no issues at all. The only things left are my cpu and motherboard. I have all of the latest drivers. I've run every cleaning program I can find for drivers and everything else. It only happens when gaming and it only started happening a lot these past few weeks. I just don't want to spend weeks getting a new mobo or another $200 on a GPU if that's not the issue. My temps are fine, never above average and temperature doesn't correlate to the issue. I could be running my GPU at 50C and CPU at 36C and it'll freeze up. I don't OC and I recently updated my Mobo's BIOS. Any ideas? Should I try reinstalling Windows?
My Specs:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1
Mobo: Asus M5A97 LE R2.0
BIOS: BIOS Date: 07/11/13 15:40:22 Ver: 04.06.05
Processor: AMD FX6300 @~3.5Ghz
Ram: 8GB (2x4GB) DDR3 PNY 1600 (not sure exact model number)
GPU: EVGA Nvidia GeForce GTX 660 2GB
GPU Driver Version: 9.18.13.2049
PSU: Solid Gear Neutron SDGR-650E
Speakers/Headset: Plantronics GameCom 780
Mouse: CM Xornet gaming mouse
Keyboard: Logitec K120
HDD: Samsung SSD 840 Series (250GB, has OS & All games installed on it) & 250GB Seagate Barracuda (used to record videos onto)
External HDD: 1TB Seagate FreeAgent GoFlex USB
I understand that's more than you probably need but I just figured I'd be thorough in case one of the above has some weird random issue that might be causing my problem. Anyways thanks in advance for any help!
**EDIT**
Upon posting this I downloaded CPU-Z and as I was installing the driver stuff that is listed in the "tools" section of CPUZ I tabbed over to my browser and it just froze like it usually does.
