Freezing At 1.5 GB of memory
When I play Skyrim it gets up to 1.5 GB of memory usage, then it freezes up and I have to Alt-Tab out of it
I have 14 GB of RAM, so I'm not running out of it If anyone has a solution please tell me
I'm wondering if I messed up something in the INI file but I don't know.
Any support would be nice.
Skyrim is a 32-bit program so you couldn't use more than 4 GB of ram anyways. It should use more than 1.5 GB of ram unless your'e using a very old verion of Skyrim...
If you are running mods, there might be a conflict beween them?
What you do with the INI file?
Worst case solution: re-install...
Try this -> SSME - Skyrim Startup Memory Editor by Queue
