FreeNAS vs UnRaid
Finally moving forward with the NAS/Server I have been talking about doing. It’s primary uses will be as a NAS, a Plex Server, and running game servers. FreeNAS is free and seems to have a lot of community support out there, but the ability of UnRaid to allow random additions of drives and simple setup it appealing as well. I am still learning how the FreeNAS pool expansion works and it seems a bit complicated currently. I also have yet to find if running an ARK Server or Minecraft server is possible on either, or would that require a windows VM in order to run ideally.
Currently my planned specs for this setup are going to be components from my “old” desktop. An i5 3570k, 16 GB of ram, and a 128 or 256 GB boot SSD with a single 6TB WD RED NAS drive…for now.
As some background, I was highly considering synology for a while but have been hearing more and more of hardware issues and spying issues and decided to step away from that choice.
If anyone can help share their experiences or perhaps guide me towards what they think will work best I would appreciate it. Thank you.
I was in a similar situation last year. Needed a new NAS/Home server. Reusing my old i5-4690k/ 8GB system. I had an 8GB USB flash drive and a 1TB HDD free and not a lot of time to get things running. Ended up downloading the trial for unRAID and I was up and running in under an hour. Great experience for the new user.
I have since added 2x 320GB HDDs as my cache pool, and 2x 4TB HDDs for my Array. Replacing the 1TB HDD I started with was easy and I had no loss of data and minimal downtime while I switched the drives.
I would recommend an SSD/ SSD’s for the cache/ cache pool if you are going to be running something demanding like multiple game servers and Plex.
There are lots of great things you can do with unRAID. One of the best resources for new user and the more advanced stuff is Spaceinvader One’s tutorials. They are brilliant: https://www.youtube.com/channel/UCZDfnUn74N0WeAPvMqTOrtA
Looking through Community Apps it seems like there are already templates for Ark and Minecraft servers running in Dockers. Here is the support thread might be worth a read so see how successful people have been getting the game servers running: https://forums.unraid.net/topic/79530-support-ich777-gameserver-dockers/
1 year on I have no issues recommending unRAID. Hardware support is great, performance and stability are great, the community is great. Yeah really impressed :slight_smile:
It is, you basically want to expand your pool with another vdev of similar redundancy. you can expand the pool with a vdev of lesser redundancy but its kind of frowned upon.
so if you have a single mirror vdev, you just need to make another mirror vdev and expand the pool from there. If you have raidz2 and you add a mirror you can still expand the pool but now your weak link is the mirror and so the raidz2 is kinda pointless because if you lose a vdev, you loose the pool.
Make sense?
FreeNAS has bhyve for virtualization. It works pretty well from my limited testing but I havent used windows for it. If need be I can try to fire one up for you. Minecraft works well in linux, and I’d imagine ARK would too, so there should be no problems virtualizing. Running them native could be a bit of a bear since freenas is based on freebsd.
I really like their stuff. I have a DS216j and I love the little thing. If you want a system that just works™ then go for it. It wont really do what you’re looking for with dedicated servers though… well at least I wouldnt ask it to. I wouldnt put much stock in the hardware failures thing or the spying thing. It phones home for various reasons. You can turn off any and all reporting. Hardware failures happen.
If you care about your data more than you care about running VMs you should probably go with freenas. Unraid is neat imo, but not ideal for critical data.
If you are going to go the freenas route, get another 6tb red and just go with mirrors IMO.
i tried both freenas and unraid for a month before deciding what to use for long term, overall i feel like the unraid community is better and more responding.
i found that doing things in freenas was time consuming, most of my time was researching how to do what i actually wanted.
in unraid everything was super simple, either thought interface or command line. i run several docker container and VM’s +my file sharing (10 disk + redundancy + cache)
that was the killer feature for me, simplicity and how fast it was to do anything or find an answer.
Yeah, freenas can be a bear. I’m certainly not a fan of its approach to security either. It really just comes down to how paranoid you are about data integrity. unraid doesnt do zfs, and that can be the key for some people.
The ideal solution to me is a ‘roll your own’ linux distro with zfs support and then you get best of both worlds.
unraid lets you throw random and spare drives and make one big massive store but, does require you to be proactive about drive health and bit rot. freenas does it all EXCEPT mix and match drives 1 by 1.
I have to look into ZFS more and find out exactly what it does. I have never really stored enough to worry about data integrity and bit rot, but now that I am digitizing my media it seems like a concern I should learn more about.
The ability to freely add more drives into unraid as opposed to freenas is appealing as well.
ZFS just checksums the shit out of your data, while also having redundancy in the disks. It has a long list of features that are pretty nice too but not necessarily special to ZFS.
https://en.wikipedia.org/wiki/ZFS#Data_integrity
One major feature that distinguishes ZFS from other file systems is that it is designed with a focus on data integrity by protecting the user’s data on disk against silent data corruption caused by data degradation, current spikes, bugs in disk firmware, phantom writes (the previous write did not make it to disk), misdirected reads/writes (the disk accesses the wrong block), DMA parity errors between the array and server memory or from the driver (since the checksum validates data inside the array), driver errors (data winds up in the wrong buffer inside the kernel), accidental overwrites (such as swapping to a live file system), etc.
Its designed from the ground up to make sure your data stays intact.
Like I said, You can add drives to freenas willy nilly. You can do single drive vdevs if you want. The problem lies in losing a vdev, thats instant pool death. if you only ever make mirrors from the get go, you only really need 2 more drives every time you expand the pool.
Lastly…
Not even freenas is so good that you shouldnt have a backup of your data, but it does a really good job at making it so you shouldnt have to restore your data unless theres an act of god. If that sounds like something you’d be interested in, ZFS is for you.
ZFS does seem to have a lot of pros.
I just wanna make sure this is what is a better setup than what I currently have so I wanna run it by you. Currently I have my main desktop, everyday use/gaming/ etc. I have a secondary dell optiplex which currently runs my ark and minecraft server and has my NAS HDD for plex which it runs off of. My big thing is wanting to have plex be accessible from the rest of the house more easily and potentially thru my phone or laptop in the future.
Is the project I am anticipating what will best serve this, or would a synology to host my NAS just be easier and leave the optiplex doing what its doing if there are no issues thus far?
well you can certainly consolidate everything into one machine with either freenas or unraid. I cant say for sure whats best for you. If you already have the hardware, grab another disk… since you’re going to need it anyway, and test a single drive vdev on freenas. If it fits, then go for it. If you dont like it, then ditch it.
