As requested.
root@freenas[~]# ifconfig
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: member of lagg0
options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
ether 00:25:90:86:8e:f8
hwaddr 00:25:90:86:8e:f8
nd6 options=9<PERFORMNUD,IFDISABLED>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
hwaddr 00:25:90:86:8e:f9
status: active
igb2: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:25:90:86:8e:fa
hwaddr 00:25:90:86:8e:fa
nd6 options=1<PERFORMNUD>
status: active
igb3: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 00:25:90:86:8e:fb
hwaddr 00:25:90:86:8e:fb
status: active
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
inet 127.0.0.1 netmask 0xff000000
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
groups: lo
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: lagg0
inet 192.168.1.10 netmask 0xffffff00 broadcast 192.168.1.255
status: active
groups: lagg
laggproto failover lagghash l2,l3,l4
laggport: igb0 flags=5<MASTER,ACTIVE>
laggport: igb1 flags=0<>
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Attached to Base_clone2
options=80000<LINKSTATE>
ether 00:bd:76:57:f8:00
hwaddr 00:bd:76:57:f8:00
status: active
groups: tap
Opened by PID 1982
bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:84:f1:56:a9:00
groups: bridge
id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15
maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200
root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 2000
member: tap3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000000
member: tap2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: tap1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000000
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 20000
member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000000
tap1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Attached to Base_clone3
ether 00:bd:d2:69:f8:01
hwaddr 00:bd:d2:69:f8:01
status: active
groups: tap
Opened by PID 2436
vnet0.1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: nextcloud_1 as nic: epair0b
options=8<VLAN_MTU>
ether 00:25:90:dd:f1:90
hwaddr 02:7b:d0:00:0a:0a
media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>)
status: active
groups: epair
tap2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Attached to Cockpit
ether 00:bd:c0:7b:f8:02
hwaddr 00:bd:c0:7b:f8:02
status: active
groups: tap
Opened by PID 2710
tap3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Attached to Nginx
ether 00:bd:14:8e:f8:03
hwaddr 00:bd:14:8e:f8:03
status: active
groups: tap
Opened by PID 2937
vnet0.2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex_1 as nic: epair0b
options=8<VLAN_MTU>
ether 00:25:90:d5:36:4f
hwaddr 02:7b:d0:00:0d:0a
status: active
groups: epair
