I have a Dell poweredge R810 with a SAS9202-16E LSI card connecting to a netapp Disk self. I can’t see any of the drives and not sure what I can do next. Has anyone else had issues getting a disk self working with FreeNAS before?
Freenas has no problems with diskshelves.
my setup is R710 with a LSI 9206-16e to a MD1200.
ssh into freenas and run camcontrol devlist
the output will be a list of devices on the hba bus, which should include drives, shelf controllers, back plans.
The one thing I have learned is make sure you update the firmware that’s able to be updated. I have learned with freenas its gets grumpy is the firmware is not inline with the hba drivers version.
double check your in the right ports on the shelf controllers
Not always the case, my MD1000 yes you have to have interposes,the will not fit without them. My MD1200 on the other hand is different I have SATA and SAS together and it works just fine
Correct, but those aren’t Netapp disk shelves. Netapp disk shelves like the DS4243 & DS4246 require the SAS Interposers but OP said he has a a DS4486 so it might just work.
