Hi everyone,
I’m planning to build a FreeNAS server as a home media and backup storage. The server will only have between 2-4 computers connected through a 1 Gbps ethernet link and don’t plan to have more that 2 computers transferring files at the same time. My budget is limited, and I have a few computers laying around my house that could be used for this project. One of them is an old AM3 platform with a Sempron something CPU, 4 GB of RAM and an NVIDIA chipset; the other option is an A6-9500E CPU build, for which I only have the CPU. I will pair a few WD Red drives to any of these options.
My doubt is whether the CPUs/platforms I have will be enough for transferring files at 1Gbps full speed or not.
If they are just laying around then download freenas and install and play around with it. You don’t have anything to lose.
Sounds like mdadm is good enough for you. FreeNAS can complicate a solution to a simple problem.
Free as likes to have 8GB of RAM, and can use more to boost performance of the storage, but not essential.
Like @sanfordvdev suggests, it costs nothing to give it a go, but be aware you may need just one more stick of ram off EBay to make it happy…
A sempron chip should work okay, and should allow a couple of users to stream from it at the same time.
Thanks for the suggestions. Guess I’m gonna have to try it out.
I haven’t read any FreeNAS nor ZFS documentation, but I did watch a few videos about this on Level1Tech’s YouTube channel, and I recall Wendell said that ZFS has a way of managing redundancy; this is what I am most interested in.
What’s the difference between ZFS’ and RAID’s redundancy solutions?
Do you know where to get documentation?
