Hey guys,
So today I remotely did a firmware update to my FreeNAS using the web GUI. Now I find I cannot access it any more.. In checking the log from the box, basically what it displays on its console I get an error, "freeNAS ntpd_initres[2226]: host not found: 2.freebsd.pool.atp.org" and in the main menu it is telling me "no configured interfaces found." I tried to reset the network config but it returned the same error message. I checked my router's ARP Table and the freeNAS box isn't registering as being connected at all.
As I mentioned I'm not currently around my box so I've been trying all of this remotely. Can you guys think of anything I should be trying to get this back up and running? I would like to get it up before I return home, pretty much ASAP considering I won't be home for quite some time..
A couple side notes: I've upgraded from version 9.2.1.5 to 9.2.1.8. the network and everything was working fine beforehand. The nic I'm using is an Intel Gigabit nic built into the motherboard.
Thanks for the help guys,
//Benjamin
P.S. why on earth doesn't shift+enter work for a soft return?? Inserting <br/> doesn't either..
