Can someone recommend what I should be looking for in a MOBO and CPU for a FreeNAS build?
ZFS, 6 bay, mini ITX
nasferatu?? with the avoton board?
Only place iv been able to find the ASRock C2550D4I here in the UK is Amazon, and there it is £254 ($430)!
Any suggestions for a more ubiquitous MOBO?
i like Supermicro over ASRock for servers, and this is slightly cheaper--- but it depends on how many drives you want to run
SUPERMICRO MBD-A1SRi-2758F-O
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182855
