Hi. I’m going to build a PC with 2x RTX 3090 (2.75 slot) using the X570S AORUS PRO AX. And I don’t know how much space there is between pcie slots. Can I fit these GPUs into the motherboard using the first and second pcie slots? Or do I need thinner GPUs like liquid-cooled GPUs?
That notation is for the number of PCI slots the card covers, so basically 3.
The motherboard you mentioned seems to have a two slot “spacer” after the first PCIe slot.
So it should be fine to use your 2 3090s with that board without modifing anything.
Thanks for the explanation. Could you answer one more question, please? This motherboard doesn’t support the sli, according to the documentation, but I want to use the nvlink. Does no sli support mean no nvlink support? Or is it unrelated?
It might not be a bad idea to create another thread asking for build advice on this system. Aside from the motherboard, there are still other important considerations like choosing a case, cooling, and power supply that can handle the demands of two 3090’s. Also, when you run dual GPU’s on X570 the speed is reduced to PCIe 4.0 x8 for each card. If you’re using them for something like AI learning this could actually affect performance and there are probably better platform choices. And if you’re using them for gaming then maybe someone could talk you out of buying two of them
Anywho, there are lots of knowledgeable people on this forum that love helping with that kind of stuff… and could save you from making some costly mistakes. Just my 2 cents
