Frankensteining for dummies? Building a forbidden archive machine
Hello all, spurred by a couple of incidents (1. clearing out my parent’s home and finding hundreds of old CDs/DVDs. 2. The Storage shortage which came up in conversation) that got me thinking laterally.
I’ve put my money where my mouth is and have started a trecherous journey of building a taboo machine. Essentially I’m harvesting a Sony CDP-CX200 Jukebox from early 2000s (mostly for the mechanism) and replacing the optical reader and the control circuits to make it a Network Attached Jukebox for reading archival data over the network, I’m thinking possibly a CM5 with a SATA/NIC hat, or just a PI5 and USBing the hardware. Still figuring that part out.
My plan initially was “How do i get all these CDs/DVDs so i can use them?” and initially it was to make a lot of space on spinning rust move it all on a NAS. But then I realized that in the past +10 years I’ve not needed to access any of this media, and maybe I would, but, even then: not often.
Acknowledgements:
  1. old CD-Rs and DVD-Rs don’t last very long, so I may find myself with failed discs, my actual plan now has to migrate all this data on to M-Disc (100GB per disc), however, the goal remains the same. Data that can be pulled up on request but remain (physically) secure and dormant the majority of the time.
  2. Jukeboxes break. The unit I have purchased was listed as “defective” however, from the videos i’ve seen online the most common defect on these units is the drive belts that fail due to rubber bands sagging and see point 3.
  3. optical readers fail. Since I’m replacing this from a CD to a Blu-Ray reader, I plan to bake that into the recipe, make it so that swapping out a drive for another should be user servicable.
  4. I am neither electronics engineer or a software engineer. I do have 30 years working with computers and have studied mechanical engineer at college, but in truth: I will be vibing my way through this journey with some AI help for the more trivial parts and some life intuitions for the rest, I believe this may be a true test of AI being of any use to a “layman”
I’m talking a big talk right now, so allow me to revisit this post with photos and observations as I go on this journey.
I did about the same project a few years ago. Only thousands of CD-Rs, hundreds of floppy disk, and about 50 old HDD. Failure rates reading any of it was low, and some of the CD-Rs are over 20 years old. I even CryoFluxed some Apple2 floppies from the 1980s and most read fine.
If the CD/DVD is a normal commercial release, and the content can still be obtained today, then I don’t see a lot of point in archiving them.
If you do want to keep some stuff, but may never need it, do the calculation on the cost involved in storing it in an AWS S3 deep archive. It may be worth the few bucks a month to make it their problem.
I solved the problem by setting up a Ceph cluster that stays powered off most of the time, but I can turn on and dump data too, especially as I have been adding to it over the years. This plan was working out great when spinning rust was cheap and getting cheaper. Not so much now, but I stocked up on drives right when the prices starting going up. I am only about 60% full out of 480TB.
I do like the idea of M-Disc and have some critical data backed up to it, but I have not found any archiving and inventory software that really fits the bill of increment forever and keeping an inventory and everything in an open standard. I have something half finished in Python, but need to find the time to get it more functional.
the entire point of archiving things is that they eventually can’t be obtained anymore, and there is going to be no way to archive them once they are not obtainable.
Or in other words, you can only archive what is still obtainable.
I saw something like that in the past and just reading the feature descriptions thought it was really cool but I’m not a datahoarder (not a serious one anyway) so I never needed it personally.
I had to ask DuckAI (chatgpt 5.4 nano model) to find it again as I forgot the name and search engines are now completely worthless lol. It’s called git-annex
To a point, yes. But I balance the cost of me personally archiving something, verses the chance of it going away. If I have an archive of a YouTube channel that has since been removed, then I likely have the only copy. So I put more resources into saving it. A DVD copy of Batman 1966 will likely to still be available in some form in 50 years, so I don’t put a priority on it.
If I ever ran out of storage, my Movies and TVShow folders are going to be the first ones deleted.
git-annex is close, but not quite. I want something that I can point to a NAS, it will index and split up the list of files so as many as possible will fit on an M-Disk. Make some ISOs with the files without changing them and let me burn that to M-Disk. Then keep that index around in a standard format so I can search that index and figure out what file is on what disc if I ever need it.
I have something working in Python using sqlite as the index, just need to work on it more.
