Fractal r4 or Corsair 350d
I like both of them so I'm having a hard time deciding between them. It seems like the r4 might have a problem drawing air through the front.
So what is your guys opinion, which one do you like  and why?
they are both good cases man. i would pick the cheapest of the 2 and put that money into the system..i will say this however, corsair has never let me down with cases.there pretty much all i use
depends if you are using an atx board or a matx motherboard.  matx go 350d   atx go r4
I have the 350D, and if you are going to be building a mATX system, its the way to go.
If you want an ODD the 350D will not look nice!
ODD?
