Fractal North + X670E Taichi VS 2 2.5 slot GPUs
Since Wendel reviewed the new North case, showing the fact it can fit a X670E Taichi, I was curious if, by any chance, anyone knows if it could fit 2 2.5 slot cards? I wanna do VFIO VMing with NVidia n rock AMD on main linux distro. And I love how the case looks, if it’s not doable, I’ll scrap the case plan n swap back to Meshify 2 XL :stuck_out_tongue:
Cheers
It’s 7 slots and the 7th slot is the bottom edge of the board, so only a 2 slot GPU would fit in the bottom slot of that board. The RX 6800 would fit down there. If you run your host on the iGPU you can use both GPUs for VMs.
I am sure by now you are already done with the build. However, I am about to start mine pending delivery of the case. I would like to see how your A670e Taichi/ Fractal North build came out. Send come pics please!
