Fractal Design Define R4 "Not So Good"
Well I was throwing a budget pc together for a customer today, went with the R4 as it was a sleekish case and was on sale at the time of purchase.
Long story short here, they didn't quite leave enough room for the power supply to vent out the bottom of the case as it is intended to do with this design. so shame on me for not paying attention to this before hand and shame on them for the cooked power supply that I have to RMA this evening.
If you have this case and are venting out the bottom be sure to put something under the case to raise it up off the floor a little more, or mount your power supply upside down.
The PSU takes in air through the bottom of the case, it doesn't exhaust unless you've rewired it.
The air intake was probably blocked by a carpet or something.
Power supply's dont like carpet....
You know, I think many of us would have noticed if our PSU's were cooking due to the design of the R4, since it is by far the most popular case for building in currently.
It seems you're blaming the case prematurely.  You've only RMA'd one power supply, if it happened twice or thrice I would probably blame the case, but it could have been you got a lemon PSU.
Also...just making sure, don't put it on carpet. shhhhh no-one will know that you did it.
I found a relatively simple solution to not wanting to put it on the floor.. I bought a $25 "Desk" which is just 4 legs and a 3 ft by 2 ft top. My PC sits on that, next to my actual desk. I've experienced the horrors of PSU's catching fire, and fire + carpet = burnt carpet.
Or just get some type cheap piece of wood/fiberboard and put it on the floor under the case. EZ. This issue you had however, highly unlikely the fault of the case.
I think there are some pretty real criticisms someone could make of the R4. I know people who have this case and claim that it is very loud and very hot. It isn't optimised for airflow, which might cause components fans to spin more than they would normally. Negating the main selling point of this case, which is the silent operation.
I'd rather take the Arc Midi and variants of that.
Best solution, take a piece of wood and put it under the case.  Problem solved :)
I've mounted my PSU with the fan facing upwards. No problems whatsoever. Also, changed the PSU fan to a Noctua. Silent and cool. The only thing I'm not diging about R4 is the extremely bright LED power button. had to modify that a little. Also the dustfilter at the botom is sometimes riddeling but sticking a toothpick between the case and the filter solved the problem and doesn't look like shit.
I feel that thread title is a bit sensationalist and to be honest blatant and easily avoidable human stupidity is not really i would consider a fair critique of this case. as the issue in reality had nothing to with this case.
I have almost an Identical setup, it also elevates it nicely to a nice viewing height, I love it.
thank you!!
i was looking for years now what was causing the riddeling and it drove me crazy!!!
just when i thought i stopped it, it startet again and i didnt know what was causing it.
would never have thought that the dust filter was causing it. :D
you are welcome my friend :)
Did you put it on carpet?
I bet you put it on carpet.
I have that case (black pearl/windowed) and it's perfectly fine. My case stays cold to the touch. The PSU is facing down to intake. Not sure why you're having problems. But again, carpet is BAD!
Must have since he hasn't replied.Maybe his house started on fire
Really? Thats strange, I know the R4 isn't exactly the best for airflow but my system basically turns off every fan except for the CPU cooler off when in idle operation and even in light gaming, this thing is dead silent unless I deliberately turn up the fan speeds.
And thank god for the amount of dust filters the R4 has, I'd take a clean computer anyday over a slightly cooler but dirty computer (I'm looking at you my former PC in a HAF 922)
My Fractal Define R4, and I love it. I have it up on my desk and the temps are usually 30 on idle. It also stay completely silent and I have 4 fans in it (1 in the back and 3 doing a semi push pull setup on my radiator in the front). I guess it's personal opinion, but i never really considered a R4 as a case for a Budget case, also what is the size of the PSU? It must be big. Anyway good luck with your problem.
Truthfully, that is what my friends have told me. Another guy has just posted in the forums claiming that his temps have gone up after switching to the R4. Put simply, I don't think the R4 is going to be kind to everyone. If I were to use an R4, I would certainly pick a GPU cooling solution that dumps the majority of the heat out the back of the chassis.
C'mon im using a cooler on my gpu that exhausts into the case and iv got no issue's venting it. also my cpu is idling around 38 on a stock cooler. i don't get how people can get bad temps specifically because of the case? they have to be doing something seriously wrong.
https://teksyndicate.com/forum/gpu/high-temperaturs-after-changing-case-and-mobo/167681
Ask him yourself. Apparently, he got his GPU temps down after switching PCIe slot on a decent quality motherboard!
*no idea*
