Hello all,
in Logan's video review of the fractal design define r4 it was mentioned that you can rotate the bottom hdd cage by 90 degrees so that it faces with the fans. I just unboxed my brand spanking new r4 and wanted to do just that as I only have 3 drives so I figured for optimal airflow I just need the bottom drive cage rotated.
After 3 hours of fiddling around with it I have no idea how to screw the the cage to the case.
I found that the rotated cage fits / aligns perfectly with the red circles in the picture below. However, no screw that came with the case fits these larger than average holes. Do i have to go out and buy some bolts & nuts to do this or am I msising something? Please help.
Thanks, Max
