Tek Syndicate! I've got a problem! Or well, not that much of a problem but still...For me it's quite an issue. I've got an FX 8350, Hd 7950 (boost edition) and 8GB single channel RAM and am getting lower framerates than I should.
When I see others with a similar setup on youtube or benchmark results, they're getting 60 fps minimum in bf3, whereas I get 50 and sometimes even 40 FPS (this used to be even worse before I fixed some things in BIOS).
This setup should also do fine on BF4 and BFH, but on BFH I get 30-50 FPS when i'm not looking at the sky, ground or a wall.
And on low I get 40-55 fps in BFH...Help?
I personally suspect it's my RAM, i've heard that the FX 8350 really really wants dual channel RAM. Is this true?
Or is it, as some say, my GPU?
I also got low framerates on Dirty Bomb up until I did the previously mentioned tweaking in BIOS. (my framerates are still lower than others with the same system. Though still good enough. Others easily get 70-120 or something like that..I get 60-80)
I would really like some help with this! Thanks!
