So in most games my FPS drops down really low for a couple of seconds and then goes back to normal.This happens even in games I know I can run no problem like CSGO , I get a constant 120+ FPS and then the game FPS will just drop down really low for some reason.
I have checked CPU and GPU temps and they seem ok, http://gyazo.com/763...7f061efdf7555a8 CPU cooler is a Hyper 212 that has recently been installed and case is a source 210 elite , i have a side fan and a rear fan for intake and then a top 120mm for exhaust.
Defrag your harddrive, check RAM useage, try to run a minimal ammount of applications while in games and see if that helps. Potentially, there could be a software error which might be reported by Windows. Look for errors/warnings which occured during gameplay. There's a quick intro on the WIndows Event Viewer here:
Umm, I'm pretty sure there was fluctuation in framerate, considering the fact that your GPU maxed out at times... and none of those images have framerate or frametime in them. Need a lot more info than this.
