I flipped my case over on its side to switch out the cpu and post test another cpu. During the time frame of pulling and replacing the cpu I found a minor leak. (a few drops over the half hour on the side) currently, running a leak test for a few hours, and nothing seems to be leaking so far. (don’t think I’ll find a leak in the vertical position) Going to double check and pinpoint the leak when I flip the system back on its side to put the old cpu back in.
Would it be safe to run the computer if I determine the leak only happens while on the side? I know I should fix the fittings with the issue, and probably just run distilled water till I can get treated fluid replacements. I just really need this system back up.
