Login was fine with Google signin
“Intro” stopped in the middle of “open your 1st notification” (after clicking profile icon, when you you move anywhere except the top the opaque white bg of the “Intro” comes up.
and at the forum home:
Network Error
while trying to load /404-body
Please check your connection.
(and Json=??? something, it went away before I could read it)
I suppose you tried to acces an area of the forum that you dont,
have acces to yet.
Because you just joined the forum’s.
As soon as you participate and visit the forum more,
you will climb at the trust level ladder.
TL2 member will give you acces certain area´s that you don’t have acces to yet.
The actuation point of the forum is about the middle of the screen, so if the end of a post you get a notification for passes the middle of the screen the notification will disappear. This is making sure you have seen the post/notification.
the " pinged by the system for fast typing" was afetr I made a second (this) post, my 1st reply
seems like Discourse need some ironing out still - BUT THE MAIN IS WAS NETWORK/SERVER RELATERD AND THAT SEEMS TO HAVE CLEARED ITSELF UP - THANKS for quick assists
I have helped fixed a few in the past, but apart from Raspberry Pi I dont really use forums any more… thanks again for the assists, and being so quick really made a difference
