So I know that the RTX 3000 series have killed off Implicit SLI and that only the 3090 can do SLI.
My question is, is there a way to force implicit SLI on the 3090, either in drivers natively via some hidden option or through hacking the drivers in any way?
I know the SLI arguments, and I am not asking if it is trash or not, or if it is dumb or not, or a waste of money. I just want to know if there is a way to reenable implicit SLI in drivers or if the cards are hardware locked out of even doing implicit SLI?
Thanks for your time and help.
I did try a bridge and bridgeless setup, when use in explicit, I believe that the software need to be able to use the gpu independently, I know that octane bench software actually can do that, I tried 3dmark extreme, I didn’t test a A/B for that test though, I hate those perfect drivers that get messed up when putting or removing the nvlink… It just doesn’t work!
