I know GNOME isn’t for everybody. Honestly, I don’t fully get the philosophy behind it either, but it’s been my favorite daily driver for the past couple of years on both Fedora on my notebook and CachyOS on my desktop, I have to admit I’ve really come to enjoy it.
Along the way I ended up writing a few little projects to make it nicer to live with. Full disclosure: I built them with claude code’s help, and I’ll say it plainly, LLM has been great for Linux dev work, GNOME included. Here’s what I’ve got so far and I like to share with the community:
howdy-fedora-helper-script: sets up facial authentication on Fedora Workstation with GNOME, all from a single script.
orrery: a live, OLED-black solar system wallpaper for GNOME Shell. It shows real planet positions and replays the gravity-assist missions from the space age, which is just fun to watch.
shuttle: push, pull and sync folders between SMB/NFS shares and local storage. It comes with a TUI, a systemd user service, a GNOME indicator and a Quick Settings toggle.
If you try any of them, I’d love to hear what you think
That being said, I’m just as curious about what everyone here has built. especial stuff that never made it to the GNOME extensions site, cool to see what everyone’s running, and I bet I’m not the only one who’s going to steal a few ideas.
If after 30 years of development, users have to create extensions to make it nicer to live with, the DE is a failure, IMHO. I’m a KDE fan, and it is “nice to live with” without extra apps.
One problem with extensions is, a user has to find the one they need, or multiple. And after every update, extensions need to be updated or break.
Does anyone use Gnome in plain version? Many distros already include extensions (e.g. Ubuntu). So it is hard to even experience plain Gnome. I suspect Debian, Fedora or Arch users are the only ones starting out with plain Gnome. I’m curious if many of those users do NOT add extensions and just use Gnome “ as is”?
I also don’t like they higher resource use (which also applies to the forks, like Cinnamon). On Ubuntu, it has a bug to show the spinning wheel after starting an app. So the user can’t really use the mouse pointer for a few seconds since the pointer still is a spinning wheel. i initially thought it is the snaps taking so long. But the wheel still spins after the app is already ready.
Anyway, thanks for your effort. How will you handle updates to the new versions of Gnome?
You state that as facts but it is merely your personal preference. I use vanilla Gnome and the only modification I did was enable the minimize and maximize buttons for the window frames. I like Gnome, it’s polished and it works.
Back in the day I used i3 and sway as well but I regularly ran into issues with applications not working correctly because i3 and sway both don’t come with all the connections to the notification system and dbus interface by default when you install them yourself.
The last couple month I was on Cosmic, developed by System76, because I wanted to try their options for tiling windows. The tiling function worked reasonably well but I am angry with them that they call Cosmic stable, it’s in a beta state at best.
I think Cosmic works for most user, but if you have a niche setup, like multiple GPUs by different vendors, a hybrid laptop or such you’ll run into trouble. I tried to overlook these shortcomings for month but in the end System76 is busy publishing new features while all these bug reports stay unfixed.
So it’s back to Gnome for me, without tiling again but the desktop environment is polished and just works.
did that require an extension, or does Gnome allow that adjustment out of the box?
I do not dislike Gnome and the “ touch screen UI” is subjective. But execution is lacking or contradicting:
they want to minimize the UI, but they don’t let you remove that top-bar (not without extensions). If they want the DE to be “ out of your way”, they should allow that
It takes 4 clicks to shut off the PC (2 on KDE). It is almost like Microsoft asking “ are you sure you don’t want to subscribe to OneDrive?”
To adjust the volume steps (i.e. from 5% to 2% per click) in Gnome you use CLI. In KDE, you use GUI
There probably is more and i didn’t spend tons of time and not as an actual daily driver on desktop. But fixing the above would take nothing away from the Gnome experience.
In software, “stable” doesn’t mean no crashes or bugs, it means no changes. Cosmic is buggy, but it also is changing. Where exactly do they call Cosmic (the DE) stable? They publish new versions a lot and I bet Pop-OS also updates them frequently. This isn’t stable at all (unlike Debian).
And how is Cosmic not just Gnome with tiling extension? I know under the hood it may differ, but look at it and tell me it isn’t Gnome.
For as long as I keep using GNOME, rn to me its a passion project so I plan to support the latest release and a few older ones behind it.
I set up CI runners that test my extensions on multiple distros for popular GNOME releases. That also let me cover older versions I no longer run, and upcoming ones before they land. My latest project Orrery, for example, is validated on GNOME 48 through 51.
As for why so many extensions fall out of support, I think a big part of it is the review process on the official extensions site. It can be slow and frustrating, and I suspect plenty of developers just give up on it as they move on.
I feel like as long as the code is opensource and available its so easy nowadays to simply point your LLM to it and make it compatible to whatever you work with including other DEs.
Yeah its a bit restricted out of the box, I have to say tho once you install the extension manager it unlocks A LOT of customization. Its totally subjective tho, DEs are plentiful and we all can pick what we like. I personally also like KDE, Cinnamon and few of the other ones.
While I don’t like GNOME in many ways, I use it when I need resizable RDP session, which GNOME does much better than KDE (at least before 6.8, which I haven’t tried yet). In RDP sessions I don’t use it much and have no need for extensions besides those in Tweaks (but why on earth they put autostart in tweaks?), although if you know something that can get window borders for qt apps please show me.
I like your extensions and the space wallpaper is quite cool even though they arent something i need on my system personally they are very cool. I to run gnome on fedora and i like how fedora gives you vanilla gnome instead of some sort of weird rice like ubuntu does. Personally i have riced my own gnome de quite heavily but now that im done it has exactly what i need and there isnt anything extra unlike with kde where i felt like i had to remove a bunch of stuff to get what i wanted. Also one thing i did that is super simple but makes things much nicer is to write a simple bash script that checks to see if extension verification is enabled and then disables it if it is and then outputs to a log file when it runs and i have it set on a cronjob that runs every 5 minutes so that if after an update my extensions “break” because the devs re enabled version checks my extension are immediately back up and running.
