Foobar lock on files
I was exploring foobar, and after moving and renaming some files using file operations I noticed a weirdness.
All the files that had been moved got a little lock. It doesn't seem to affect the usability of the file.
What does this mean and how can i get rid of it?
It could be that your OS recognizes them as system files. Try changing the ownership back to yourself. Right clicking on files or folders, going to properties and pocking quickly into security should give you the right options. You can click on the user you are signed in under and then apply changes to the rights of reading and writing those files. Giving yourself full access should remove the padlocks.
