Foobar help
okay so i just got foobar 2000 and so far a really like it. its cool cuz its customizable and it sounds better. i added all my songs on there but i still dont completely know how to use it. like this is a dumb question but i dont know how to rename songs lol? like with itunes, all you did was right click and go to info and then you could rename it. or you could just click once on the song and then click again and it would highlight it so you could do it that way, but i dont know how to do that with foobar. also is there a way to add songs to my ipod with it? like sync it with it from foobar instead of itunes? i bet you cant cuz apple is a whore and you have to use everything apple sooo idk if theres a crack for it or if you gotta unlock it or something idk?
thanks!
tsrichter24 wrote 2 hours ago ยป
thanks!
http://lmgtfy.com/?q=itunes+crack
There you go sir
FAIL
8 bit that doesnt help him whatsoever.
there are plugins for ipods, heres one... http://www.hydrogenaudio.org/forums/index.php?showtopic=19156
and as for renaming the songs..idk
edit: if that plugin doesnt work just search around there are tons
oh ok thanks!
as for renaming... just select the ones you want to rename and right click, then select'properties'... you can even rename multiple items... if you just need to change band name or album name, etc.
PROTIP: Don't download songs using LimeWire.
'buy' albums and rip them with Windows Media Player in .flac. It has auto tagging so it's no problem.
ok thanks for the rename thing. il try out that ipod thing soon
