Hello I was running [email protected] and i was noticing that my gpu would fail out i have tried restarting the computer.
Log is here http://pastebin.com/3KiHxTpJ
Thanks
According to a tip on LTT, you can solve it by opening the config window, completely deleting the GPU slot, rebooting and then creating a new GPU slot.
I tried doing that and it will start then fall then my screen will flash black.
edit i just saw i should give it some time
It was working for some time and then it failed. I have a GTX 1070
