Fm2,am3 and am3+?
so lately I've been thinking what these fm2,am3 and am3+ socket types represent and which one would be a better one for a long term use I'm really confused which one to take and advice or suggestion would be awesome....
Just go with a AM3+ and a dedicated GPU setup realy ☺
 fm2 is apu. but for a good gaming build i would suggest a decent AM3+ motherboard  FX6300 or FX8320/8350 and a good gpu like youre choice. depending on youre budget. good gaming card HD7870 (XT) 7950 or 7970.
but is all depending on youre budget.
so if you want good adive please tell us youre budget ☻
Yeh mine is like 600$ to 800$ I'm thinkinto not to compromise with the GPU so I'm thinking of something like a  7979/7950/7870 or a 660 ti and sure now that I know I'll take a am3+ mboard :D
if you can spend  arround 860 dollars then i found this.
http://pcpartpicker.com/p/P8Jt
 or this: 833 dollar
http://pcpartpicker.com/p/P8N3
let me know what you think., of you can safe some money if you not plan to do any overclocking, or you never plan to run a crossfire or sli setup, to go with a decent 970 chipset motherboard. that can safe you upto 35 dollars.
Nope Im not gonna overclock or sli or crossfire at any costs so it should save me some more bucks and I could take out the cooler too right? Well that was a great build and I was thinking is the processor could be ws wrapped for an i5?
Swapped*
I would go with
http://pcpartpicker.com/p/Pep5
http://pcpartpicker.com/p/PesE with a i5 $824.66
the cooler i choosed is 19 bucks and does a better cq more silent cooling job, you can also use the stock cooler, works fine, but its only getting very noisie in gaming.
i chanced the motherboards for you to  970 board.
http://pcpartpicker.com/p/PfLF
http://pcpartpicker.com/p/PfMF
and i also put this one. take a look at this
http://pcpartpicker.com/p/PfNH
if you want an i5 build then maybe look at the  build from cooperman, itsrealy intressting.. only i would suggest by that build, take a higher psu 750W 80+ bronze atleast.
Thanks a ton guys my build is almost trendy but I've got a last question
i live in India so here there aren't many options for me :( so I buy it from a shop so today I went there and he says he can either give me fx 4100 or a i5 so what do you guys think? I've got a 20 days to decide btw I'm leaning towards the fx 4100 because its a 3.6 ghz and its got 4 cores right? So what do you guys think please let me know
Ready*
if you can only choose between an i5 or the FX4100 that sounds realy strange to me, but denn go with the i5 :) the i5 2500 or 3570 will perform better then the FX4100 bulldozer
do you have a india website for me?  where i can see hardware parts. cause those 2 cpus they want to sell you you are old ones realy.
I dont shop online so I can't tell yotht he website but what are the CPU's you suggest so when I go to give the final order I would know and I could ask him about the other CPUs
You the*
i was suggesting a FX8320 or a FX6300 AMD or FX8350, but thats the most expensive amd cpu to get atm.
I think he Has the fx8350 and the Fx8320 thanks a lot for the help if not I would have gone for the i5 :D now I'll tke the fx 8350 or the 8320
my plessure
yes plaease Take the FX8350 or FX8320, both are good choices.
