I have just started to use NicehashOS for mining.
It boots from USB and then runs from RAM so any reboot wipes settings.
I can remotely control stop/start mining from my smartphone.
When GPU is not under load I want the fans to spin at 0 RPM to save on noise. I’m assuming this will need to be flashed in the vBIOS?
I’m tech savvy but never done a GPU bios flash so not even sure if this is the correct thing to do.
Any help appreciated
