Flac Converter
Hey guys I am looking for a Flac Converter recommendation.  I really just want the converter and not a load of malware.  Does anyone have a suggestion?  Thanks for the assitance in advance.
http://download.dvdvideosoft.com/FreeStudio.exe
One of the best freeware I know of, just be sure to uncheck the necesary boxes during instalation. :)
I'm lazy so I just use Audacity.
Is this FLAC > ...? If so, use Audacity as Omar said, or Foobar2000 should handle file conversions (Assuming you use Foobar2000)
Heh... I saw this and I remembered that I had found this awesome little freeware utility that did this, only when I went to look it seemed it didn't survive the latest OS reinstall.
Today in a flash of inspiration I actually managed to dig it up.
So here you go:
http://www.sector-seven.net/software/flicflac
Simple, freeware, open-source, does absolutely nothing than convert to and fro.
