just got the Intel Arc B580 installed and keep having issues with getting the Intel driver to work under Windows 11 inside a VM.
It throws error code 43.
What works is booting “bare-metal” without QEMU/KVM.
Also I managed to get it work once in the VM, but could not figure out why.
After a reboot it stopped working. Lol.
This appears to be a general issue with 6.12+ and QEMU <= 9.1.x, also affecting AMD GPUs.
The vfio-pci-core driver can now map 2M and 1G pages for PCIe BARs, and from what I understand, only QEMU 9.2.0 aligns the mmap calls properly for that to work consistently.
I’m having issues with my B580 trying to pass it into a VM. It seems to all work until I install the Intel GPU drivers in Windows 11. Every time after that the mouse starts to not behave properly and then the host OS fails to boot after that.
I am not really sure what I could be doing wrong that breaks the boot device of the host.
mounting 'PARTUUID=...' on real root
BTRFS error (device nvme0n1p2): bad tree block start, mirror 1 want 310263808 have 260620288
BTRFS error (device nvme0n1p2): bad tree block start, mirror 2 want 310263808 have 260620288
BTRFS error (device nvme0n1p2): failed to read block groups: -5
BTRFS error (device nvme0n1p2): open_ctree failed: -5
Well to follow up I have been using the scripts just fine to bind and unbind the B580, but now I am getting kernel panics when booting the VM. It seems it is specifically upon binding the GPU to VFIO. Everything continues fine, but shutting down the system is where is gives the beautiful Blue Screen with the QR Code.
Continuing my discovery. I was able to narrow it down to having a display connected to the B580 upon booting the host system. If no display is connected when the host is booted, no kernel panic everything works fine.
Unsure how to proceed.
I even use the kernel parameter video=HDMI-A-3:d to disable that port outside the VM
This post also found that no display connected is required. But for me it specifically only needs to be not connected when booting the host.
video=efifb:off didnt work
messing with the frame buffer didnt work.
This type of removal didnt work and also kernel panics echo “1” > /sys/bus/pci/devices/$gpu/remove echo “1” > /sys/bus/pci/devices/$aud/remove sleep 1 echo “1” > /sys/bus/pci/rescan sleep 1
This causes A LOT of kernel panics echo "1" > /sys/bus/pci/devices/$gpu/reset echo "1" > /sys/bus/pci/devices/$aud/reset
When booting the host with no display connected the module Xe only has 4 processes using it, If a display was connected on boot, then it has 7 processes using it.
