Fix needed for screen tearing on eyefinity
Hi to all readers!!
I am running a AMD 1090T with 2 XFX 7970's in crossfire, runs pretty well and i decided to go with a eyefinity setup with 3 screens in landscape!
BUT...
I have been annoyed so much by the screen tearing (far left and right monitor) they are connected with a dvi to a active mini display-port adapter
nothing really found so far that could fix it!
People say that i need to use all my monitors on a display-port connection, but my card only has 2 mini dp connections and i have to use the other monitor (center) on the dvi connection.. also by using the mini dp on my second card will not work because they all have to be connected to 1 physical gpu..
This fix would help this horrible tearing for everyone that have this problem!
Edit: And i can't just buy a new gpu that have 3 display-ports.. unless i get donated by all you lovely people of tek syndicate :p
Install this GPU stat utility and run it for both GPUs and post the screenshots for both
http://download.cnet.com/GPU-Caps-Viewer/3000-2086_4-75449929.html
and please post a complete list of pc specs so we have more to work with.
