Does anyone know if this will fit in a Bitfenix Prodigy, and if I have to remove anything to do so.
You may have to remove the hdd cages and it should fit. I'm about 50% on this one because the 7970 is pretty shlong
It will fit fine if you take out the top hard drive cage which will leave you room for 2 hard drives and 2 ssd
