Fisrt build
I need to know if these parts are all compatible together.
Specs:
CPU: AMD Phenom II X4 965 Black Edition 3.4 GHz
GPU: radeon hd 7850
RAM: CORSAIR Vengeance (2 x 4GB)
PSU: OCZ ModXStream Pro 600W
Motherboard: GIGABYTE GA-970A-DS3
HDD:Western Digital WD Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb
Case: COOLER MASTER HAF 912 RC-912-KKN1
Here's the list on newegg
http://secure.newegg.ca/WishList/PublicWishDetail.aspx?WishListNumber=15953969
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=15953969
get this instead, cheaper and its not OCZ
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
I've used over 60 Rosewill Green series PSUs personally and recommended hundreds online with no complaints, they also recieve serveral online awards
also get the cooler master hyper evo 212 like 34$ great to keep that CPU cooled if your overclocking
Looks like a great PSU but it's not modular. Do you think my case has the place for the cables?
I will get it later. This is my first build so I won't oc at first, but I will oc after I learn more about it.
I would swap out the Mobo for this one
and case for this one or this one
