First time using HBA, everything works but HDD activity LEDs
Hello,
I set up a new home server with TrueNAS Scale running on the AsRock ROMED8-T2 board and AMD Epyc 7282 CPU with 12x 14TB Seagate Exos connected through a Broadcom 9500-16i HBA. The backplane is connected to the HBA with two SlimSAS to Mini SAS connectors and everything works great . . except I only have blue drive presence LEDs on the front of the chassis – no green activity LEDs.
This isn’t a big deal in the grand scheme of things, but it keeps bothering me since it seems like it should be so simple. If anyone has any insight as to why this is, I’d appreciate it.
Oddly the activity leds are the most troublesome aspect of home built servers.
First thing is try a few different types of random hard drives that you have laying around and see if any of them will kick the activity lights on ever.
If the lights test good with any other drive then you might try looking for different firmware for the drives that dont light the lights.
If no drives get the activity lights working i would double check all the power connectors, then look for controller and backplane firmware (if it is a smart backplane) otherwise some backplanes have jumpers that can disable/enable features.
One of my current arrays has 8 ‘identical’ drives but 2 of the drives have a later manufacturer date and firmware. On those 2 the activity light is inverted from the other 6. Annoying.
Usually if i can get all the lights in each array to match i am happy. But thats still a fair amount of work usually.
