First time gaming build - Help appreciated
Hey there, this is my first time building a pc and i would like some help. In the past couple of weeks i have been browsing Gaming forums and Buildapc subreddit, and after some researching i have came up with the following build:
[url=http://pcpartpicker.com/p/j89R]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/j89R/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/j89R/benchmarks/]Benchmarks[/url]
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($27.98)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($38.99)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($77.99)
Storage: OCZ Vertex 4 128GB 2.5" Solid State Disk ($89.99)
Video Card: HIS Radeon HD 7870 2GB Video Card ($199.99)
Case: NZXT Tempest 410 ATX Mid Tower Case ($69.99)
Power Supply: OCZ ModXStream Pro 600W 80 PLUS Certified ATX12V / EPS12V Power Supply ($43.98)
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive ($24.52)
Monitor: Asus ML228H 21.5" Monitor ($149.98)
Total: $1048.39
(Prices include shipping, taxes, and discounts when available.)
I would like to know if all this fits together and if you think i should improve something, my budget is around 1100$.
Thanks in advance
Don't use OCZ PSUs
Get that Heatsink if you intend on OCing past 4Ghz
If you aren't going to OC then THIS is all you'll need
That GPU OCs like a Beast
That moniter is a bit better that yours
If you really REALLY need a optical drive get THIS, you can install windows Via Flash drive, its also quicker
Seems good, but i cant see the monitor link and since i live in Denmark i cant get Rosewill products
Ah you listed amrican sites, what site should I use for part shopping?  I doesn't matter if its in a different language
sorry about that
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236112
but newegg and NCIX don't ship to denmark so you'll need to find a online site or a local store with a online parts list with prices
gigabuster you should really make a recommended parts list, might save yourself some work in here =P
yeah but it wouldn't be as good as a custom list for each individual person, plus combo deals and Promo codes change a lot so you have to keep on your toes
what I REALLY need to do is a guide that shows HOW I find the Cheapest, fastest, and most reliable parts and let the...
OVER NINE THOUSAND!!! people with builds to do do it themselves
Exactly the reason I ignore these threads if I can't reply with a fix of only a part or two =P
I will be using this site for buying the parts www.computersalg.dk
Are there any other psu there are as good as rosewill if i cant find them in Denmark?
cosair and cooler master
