First Time Building a PC
Hello forum! I recently decided to build a pc, but I have very limited space so I went for a mAtx build. This is what I
came up with. I also have a max budget of 830, with os and a monitor.
PCPartPicker part list: http://pcpartpicker.com/p/JA0B
Price breakdown by merchant: http://pcpartpicker.com/p/JA0B/by_merchant/
Benchmarks: http://pcpartpicker.com/p/JA0B/benchmarks/
CPU: Intel Core i3-3220 3.3GHz Dual-Core Processor ($122.98 @ SuperBiiz)
Motherboard: Asus P8H77-I Mini ITX LGA1155 Motherboard ($99.99 @ Newegg)
Memory: Corsair 8GB (2 x 4GB) DDR3-1333 Memory ($42.39 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($67.99 @ NCIX US)
Video Card: Galaxy GeForce GTX 650 Ti 1GB Video Card ($130.66 @ Newegg)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case ($79.99 @ NCIX US)
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply ($34.99 @ Newegg)
Optical Drive: Samsung SH-224BB DVD/CD Writer ($17.98 @ Outlet PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Monitor: AOC e2251Swdn 60Hz 22.0" Monitor ($119.99 @ Newegg)
Total: $836.94
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-03-14 11:12 EDT-0400)
Also, PPP is glitching very weirdly, the gpu is 129 at newegg. I think the PSU might be a bit low for this, but
suggest any changes within my budget!
Forgot to mention, I'll be playing Minecraft, ACIII, BO2, Far Cry 3, BF3, Skyrim and possibly Borderlands 2.
I'll also be recording Minecraft and Far Cry 3, I have a spare hard drive for that.
No help :C
bump
Could you update your PCpartspicker link? It doesn't work.
fixed
do you realy prefer intel?, with it-x mainboard?
cause you can have a much better build for 800 with amd :) on atx
I need the space, my room is too small
ah okay thats a pitty otherwise i found this.
http://pcpartpicker.com/p/JFyg
performance is much better then the i3 :)
i can look if i can find something with a  micro atx and minitower
im not rebating this build, it's not worth the time.
http://pcpartpicker.com/p/JFHl
this the best you can get for gaming  for  under 830 atthe moment. the i3 is crap
why a 750w psu?
also, i want to keep the prodigy case :(
then you better go with the i3 setup then :)
i cant find any  am3+ boards compatible with mini itx :)
You should at least get 1600MHz memory! 1333 is on the slow side.
and if you can the 2gb 650 ti as well
The i3's are fine for gaming.
All this looks just fine. Go for it and enjoy your gaming rig :). and stg44assault, You will never feel any difference in real world going with faster RAM, it is only when benchmarking that you will see a little difference, the RAM you have here is just fine. I have 8GB of 1333MHz RAM in my gaming PC and has never had any problems with my RAM being slow or anything.
