So, I'm building a computer for the first time. I know almost nothing about this kinda stuff, so I'm probably going to fry the motherboard or something if I don't consult you guys. Will this build work? (My budget is about $780):
$90 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139040 CORSAIR CX Series CX750 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
$100 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727 AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor
$330- http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7369714&csid=_61 Sapphire Radeon HD 7950 OverClocked Ed. 3GB GDDR5
$35 - http://www.frys.com/product/7275473?source=googleps&gclid=CMzFi7-n17QCFQU5nAodGBAAKA Patriot Viper 3 Red DDR3 8GB 1866MHz Dual (2x4GB) Modules PV38G186C9
$40 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227 COOLER MASTER Elite 430 RC-430-KWN1 Black Steel / Plastic Computer Case
$75 - ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
$85 - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Internal+Hard+Drives-_-N82E16822236339&gclid=CN7VloOU5rQCFQWnnQod8iMACw Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
EDIT: Okay, base on feedback I created this: http://pcpartpicker.com/p/xBGy
How does it look?
no it will not you have an amd brand cpu with an intel motherboard. also u might want to look into another power supply. While that one looks like a good deal i've heard of that brand before, but when your dropping this much on a computer i'd hate to see it get fried because you've skimped on the power supply. you wanna look for 80+
as far as motherboards goo i'd go for this one maybe for that cpu. http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
and use the extra cash on a different psu like...http://www.newegg.com/Product/Product.aspx?Item=N82E16817139040
Ok, thanks for the advice. I'll go ahead and use those parts.
http://pcpartpicker.com/p/xqEY
This is a sweet build it made with the case you can get what ever you want that fits ATX motherboards it just put one in like in there
You can use that memory you listed with these parts too
That looks good. I might do that, but the 7950 looks like a much better card than the 7870. It all depends on what will suit my gaming needs.
I would drop your RAM to 8GB's, you will rarely use more than 8 and you could always add more later. Here is a build I put together. I switched to an i3 processor because they are very close when comparing the to CPU's but the i3 destroys the Phenom when it comes to single core performance.
http://pcpartpicker.com/p/xCd3
here you go best build for the money
here you go best build for the money http://pcpartpicker.com/ca/p/xCFi
Just saying the 970 is an AMD board.....
http://pcpartpicker.com/p/xCXK
You could probably get higher performance parts but I hate having low quality stuff.
