Hi,
Could I get some advice for this build?
- CPU: Intel Core i5 4670K
- GPU: MSI Radeon R9 270
- MOBO: Gigabyte GA-Z87-D3HP
- HDD: Toshiba 1TB
- RAM: Fujitsu S306 64GB SSD
- RAM: 8GB Kit DDR3-1600 G.skill RipjawsX
- PSU: Antec Neo Eco 520C Bronze
- Case: Coolermaster N300
I will be using this build for some light gaming (the most 'graphic-intensive' game i play is CS:GO) and I don't plan on running every new game at their 'ultra' settings; hence I am opting for a cheaper GPU.
Furthermore, I won't be overclocking the 4670K at the moment, but I plan on doing so in the future (to at most 4.0ghz?) so I'm not sure if this motherboard will suffice; I also understand that I will need an additional CPU fan if I am to do so.
How much is the build total? I would suggest trying to fit in a 120GB SSD as 64GB is very small.
The build is about $960 AUD. I've been having trouble deciding between a 64gb and 124gb SSD as well. Currently I have about 50gb of my hard-disk as applications. I plan on just running just Windows 7, Microsoft Office, and other 'essentials' off my SSD, and everything off the HDD.
I am a bit concerned whether my PSU, Motherboard, and CPU will be compatible. Also, what should I look for in a case?
I'd get the Samsung 840 evo 120gb, I've had a few and they have worked flawlessly, 60gb will fit your stuff, but leaving a bit extra space on you C drive will speed things up a little due to cache ect
Also that budget, is it including screen, peripherals and your copy of windows? Do you need wifi, blu ray burning, a basic dvd drive ect? This info will be very helpful getting a build in your price point.
My recommendation if you don't need any extras is to go to and AMD Fx-8350, its not quite as fast as the basic haswell i7 but it beats the heak out of any i5 and actually overclocks quite well itself, especially with a decent motherboard. One thing is it does use far more power (about double a i5 or i7) and that ends up as heat, however any decent aftermarket cooler can handle that output and its a few cents a year of power, so its certainly the better value. Here is a build I did, its weakest point is the GPU but its sounds like its more than you'll need anyway http://pcpartpicker.com/p/2vt8W
