First Time Build - Noob Alert
Hey Guys! I've always been a console gamer but I think it's time I switch to PC. I literally have NO idea how PC stuff works but after a couple of weeks of research, I've decided to go for the build below!
Note that I'm on a strict $850 budget. Please review it and comment whether its good or need some alterations:
http://pcpartpicker.com/p/2TO7v
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor = $219
CPU Cooler: Cooler Master Vortex Plus 54.8 CFM Sleeve Bearing CPU Cooler = $25
Motherboard: Asus H81M-C/CSM Micro ATX LGA1150 Motherboard = $66
Memory: Corsair 8GB (2 x 4GB) DDR3-1600 Memory = $90
Storage: Western Digital Caviar Green 1TB 3.5" 5400RPM Internal Hard Drive = $82
GPU: HIS Radeon HD 7850 2GB Video Card = $170
Case: Cooler Master RC-430-KWN6 ATX Mid Tower Case = $50
PSU: Corsair Gaming 700W 80+ Certified ATX Power Supply = $155
Total = $871
I plan on using it solely for Gaming and some regular stuff (Assignments, Presentations, Internet, etc.) And I hope that it would serve me for at least 1.5 years before I go for an upgrade.
Thank you!
Well, I would recommend going for a 500W 80+ Bronze for much cheaper, go for an FX 8320 and a M5A99X R2.0, a cooler master Hyper 212 EVO, and a GTX 760 or 270X. You'll get more for your money for gaming.
http://pcpartpicker.com/p/2TSmL
Et voila.
How about this build-
http://pcpartpicker.com/p/2TRRS
I used the AMD 6300 over the i5 4670k so I could get the GTX 770 in your budget since the cpu dosen't matter that much in gaming. The 770 is a vast improvement over the 7850.
Here are some examples- Battlefield 4 Ultra @ 1080p
7850- 35 fps
770- 55 fps
Crysis-
7850- 27 fps
770-  56 fps
I hope this helped and good luck with whatever you choose to go with!!!
I support this build all the way, it has amazing processing power, Goood cooling,(replace mobo with http://tinyurl.com/m8mhozt) Good Ram, solid storage, solid card, nice case and a reliable PSU.
Save some money and get ADATA Ram
http://www.amazon.com/gp/product/B00DNZBTQ8/ref=oh_details_o09_s02_i00?ie=UTF8&psc=1
This $80 power supply from thermaltake worked just fine for me until I went SLI
http://www.amazon.com/gp/product/B00BK7BEPC/ref=oh_details_o09_s01_i00?ie=UTF8&psc=1
Storage alternative http://www.amazon.com/gp/product/B00EIQTKAS/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
Edit: the Ram was $60 when I bought it from amazon back in August now for whatever reason it is $86
Go caviar black 64mb 1tb its 87 on newegg.com
WD Caviar Black 1Tb sata3 64mb cache 87.95
Hyper T4 29.99 check to see this fits im not sure
G.Skill RipJaws 2400MHZ CL10 2x4gb 81.99
SeaSonicUSA 750W Bronze Modular PSU 119.99
savings $46.03
thats enough to upgrade to Z87 msi board
MSI Z87 MIlitary Grade mATX
Cooler Master 430 Elite 34.99 (44+$10 card) free shipping
PSU RAM BOARD HDD and COOLER ALL BETTER PARTS!!!!!!
keep gpu
843.94
or
SEASONIC 650w Gold Psu 89.99
GTX760 PNY Reference 239.99
ADATA 2x4 gb 1600 69.99
 872.88
 for 2 bucks your go from a gpu score of 3709 for the amd to 5003 on the nvidia thats a huge gap
 I budgeted this build at about 360-410 watts you could go with the 650 watt psu and the gtx760 btw that case i believe does not come with a rear fan grab a 120mm double check
BUILD IT!
The chip he wants is not compatible with that motherboard
I think he's referring to the 8320 build.
I like the Asus M5A99FX Pro R2.0 board since it has digital VRMs.
