First Time Build - Need Review
Hey guys, so I want to build my first computer this summer so I can actually play games at 1080p and playable frame rates. I currently have a laptop with a 2nd gen i7 and Intel HD 3000 Graphics which yields almost no performance at anything above 720p and I have to play on all low settings. I will be playing Skyrim with some mods, Tomb Raider, Guild Wars 2, League of Legends, The Witcher Series, among many others that I have in my Steam Library but could never play. So my budget is $600 and I have come up with a build with the help of the /r/buildapc subreddit. After all of my rambling, here is the build:
PCPartPicker part list: http://pcpartpicker.com/p/2SvCK
Price breakdown by merchant: http://pcpartpicker.com/p/2SvCK/by_merchant/
Benchmarks: http://pcpartpicker.com/p/2SvCK/benchmarks/
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor ($114.99 @ Amazon)
Motherboard: MSI H81M-E33 Micro ATX LGA1150 Motherboard ($55.38 @ Newegg)
Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1600 Memory ($80.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Amazon)
Video Card: MSI Radeon R7 260X 2GB Video Card ($149.99)
Case: NZXT Source 210 (White) ATX Mid Tower Case ($45.98 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply ($49.99 @ Amazon)
Total: $557.31
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-14 10:27 EST-0500)
Take a look at this. I didn't include a GPU because people have their preferences when it comes to that.  You have about $270 to spend on a GPU, and still be under $600.
http://pcpartpicker.com/p/2T6Ue
Looks almost the same as mine but you found a combo deal that took some money off. So with that $270, would you recommend a GPU? An R9 270X maybe?
You'd be able to get a better rig by going the way of AMD for this budget,i think. Look at the Athlon line of CPUs.
If going with AMD I would recommend the FX-6300.  It's about $105, and obviously you'll need a different motherboard.
 Build w/AMD FX-6300: http://pcpartpicker.com/p/2T801
well its great that you doing some orientation allready, but hardware prices fluc´s alot, so till summer prices would be diffrent basicly.
http://pcpartpicker.com/p/2T8gP
I second this. This cpu is much more powerful than the i3 you selected and it's cheaper to boot. The only thing i would change in this build is a dual channel memory kit but this will be an awesome build with an R9 270 or similar video card.
For a $600 budget, I think this would be really good as Tomb Raider in particular recommends a quad core
http://pcpartpicker.com/p/2T8u7
I was gonna suggest the 6300 but given his budget...Athlon could save him a few more bucks. But i see your build.Not bad,bro.The only thing i'll change is getting an Asus mobo.One of the R2.0 versions
That build is a little over my budget, probably due to the cpu cooler and the GPU.
If you're going AMD especially you want a CPU Cooler.  I would not even consider the 6core without one.  Here you could probably scratch the cooler and be ok. Is your budget closer to 500-550? you could use a 7870 instead, that would still give pretty good performance
I also recommend to go with an AMD build in your case, but I wanted to give you an Intel option as well.
The motherboard is also more future-proof, in my opinion (correct me if I'm mistaken).
http://pcpartpicker.com/user/Cryotide/saved/3KPO
"The motherboard is also more future-proof, in my opinion"
Probably, but I don't know how much you'd want to upgrade a build this budget tight, probably better to go for more performance/present value now
spend another 40 bucks and get a caviar black 64mb cache.
I see so many people recommending this processor. For gaming why is the FX-6300 so much better than the i3? I know it is 2 vs. 6 cores but the i3 has hyper threading and faster single core performance. I would also like to upgrade to an i5 later on so I don't know if I would want to buy a new motherboard and processor if I went the AMD route. Plus I have heard that most games don't even use 4 cores yet, but I know it will be more common in the near future. This is why I decided to go with an i3 now so that I can easily upgrade to an i5 to take advantage of the 4 cores. How is my logic? Right or wrong?
Thank you for all of the comments and dialogue guys. Could we keep the suggested builds below $600? Most of them are around $650
I would say $550-600, is the sweet spot.
Hyper-Threading isn't particularly useful for gaming/streaming, the extra physical cores help a lot more than the hyper-threading although he i3 is fine for productivity.  It's a viable choice if you want to get an i5 later, but for gaming its not that necessary and keep in mind if you want to upgrade the cpu it won't be worth it (For Gaming) if you don't upgrade the GPU as well which probably means upgrading the power supply and maybe even the case. you still might want to upgrade the mobo as well depending how cheap you go.
http://pcpartpicker.com/p/2Tald - $516
As of right now, PC part picker says I am at 258W with my originally posted build. I think that an i5 and a new GPU wouldn't get to 500W of power, or am I wrong? If I had more money would want to get an i5 and an R9 270X or 280X. On PC part picker, an i5 with a 270X will only pull 353W of power.
