First time build help
I'm new to the whole build-your-own-pc thing, but I'm trying my hardest haha.
Currently I'm on a budget of about $650-$700. I would be using the rig for just about everything, from light/medium gaming to video editing to audio editing to surfing the web. I plan on upgrading as time goes on and I get the money, so I'm not so worried about everything being top-of-the-line right now. Just so long as it's pretty good and it works.
So far I have as follows:
(Motherboard) GIGABYTE GA-Z68X-UD3H-B3 : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=353599&sku=G452-0144
(GPU) ZOTAC ZT-40609-10L : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2257502&sku=Z700-0431
(Optical) Sony Optiarc AD7280S-OB 24x DVDRW Drive : www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1387814&sku=O451-1030 OEM
(HDD) WD Blue WD10EALX 1TB Desktop Hard Drive : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7288051&sku=TSD-1000EALX
(Case/PSU) XION XON-180PCB 5 in 1 Mesh Mid Tower Case : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1913007&sku=A406-5004
(RAM) Patriot G2 Series PGD38G1600ELK : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7114146&sku=P33-5305
(CPU) Intel Core i3-2120 : http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7295299&sku=I69-0212
I've done my best to try to build a pc that would work for me, although I just wanted some input/help from anyone that would be willing to give advice.
Thanks for reading. :)
$700 build-has GT 430
DO NOT WANT
hold on guy I'll hook you up with a system that's MUCH better for the money
okay I made 3 builds one is good video editing and the second one is a ballance of editing/gaming and the third is good at gaming
Editing
CPU/MoBo- http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1029178
2133 RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231518
1TB HDD- http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
DVD burner- http://www.newegg.com/Product/Product.aspx?Item=N82E16827151256
Case PSU- http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1046225
(optional, $25 over budget) GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130586
Editing comparisons
CPU- http://www.anandtech.com/bench/Product/289?vs=551
GPU- The HD 4000 and 210 GT are worse GPUs than the 430 but, you can grab a GPU down the road, you'd be in tears to replace your $220 CPU with a $330 CPU rather than a $34 GPU with a $340 down the road
Balance
CPU/MoBo- http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1030095
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814131477
Balance comparisons
CPU- http://www.anandtech.com/bench/Product/289?vs=288
GPU- http://www.anandtech.com/bench/Product/610?vs=536
Gaming
CPU/MoBo
GPU- http://www.newegg.com/Product/Product.aspx?Item=N82E16814162091
Gaming comparisons
CPU- http://www.anandtech.com/bench/Product/289?vs=363
GPU- http://www.anandtech.com/bench/Product/610?vs=543
what I reccommend in order of preferecne
Editing>Balance>Gaming
but ALL of the choices I gave are better than the ones you had (with the exception of the GPU on Editing, but it edits like nobody's business)
later on I would Highly recommend getting this heatsink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
Sorry, those links aren't working. It keeps redirecting me to the Newegg home page instead of the product page. :(
Could you give me the names/numbers of the different components?
that's weird, its working for me on firefox, I'll edit my post, can you get to the pages now?
Nope, it's still taking me to the Newegg homepage. :(
what browser are you using?
I have it working on Firefox and Chrome, and even IE, your not using safari or opera are you? its pretty weird its not working on Links themselves, what about java, newegg uses it
I use firefox and I have java, so I have no clue what's going on. :S
Could you list the item names and I could search them myself on newegg?
