First Time Build Help! (Please)
I have an idea of parts in mind that I have my heart set on for my build and ill list what I plan to buy but their are still some missing components i'd love to get some advice on!
CPU- AMD FX-6300
CPU Cooler- Cooler Master Hyper 212 Evo
RAM- Kingston HyperX FURY 8GB 1600MHz DDR3 (2x4gb)
Case- Corsair Carbide Series SPEC-02
Power Supply- EVGA 500 W1 80+
Hard Drive- WD 1TB Black or Blue?
Graphics Card- MSI GeForce GTX 980 Ti
My questions are:
What operating system should I use? Is windows 10 the "latest and greatest"?
Do I really need such an expensive graphics card? (I plan on getting a 4k monitor or at least a nice 27")
For the motherboard I wanted an MSI 970 Gaming AM3+, but if I can go cheaper here and still get something solid to overclock with I could put the money towards a graphics card.
Display suggestions???
My machine will be for the occasional work assignment, but mostly dedicated towards gaming and streaming!
All suggestions are welcome, I don't know much but I really want to get back into PC gaming!
budget price? and area. (a 980ti on a nastey cheap psu is a bad idea as is trying to run it with a FX6300)
Around $1000 Ive considered a AMD- Fx 8350, I really like to idea of AMD but I'm open to an intel based system. Why is a cheap psu and an expensive graphics card a bad idea??
Because it will more than likely kill the PSU and damage other components of your system. If you have a thousand dollar budget 4K isn't really a good option to shoot for. You would be better of going with 1080p or 1440p. The 6300 and the 8350 will also bottleneck the 980ti really badly meaning you probably couldn't do 4K very well anyways. I'll post a build in a few minutes.
Edit: Sorry I don't know how to type lol.
A cheap psu isn't always a bad idea, what you probably heard was to look out for cheaply made psu. This is especially bad for your system because psu has a higher failure rate if not made with quality components and with a high efficiency rating (Efficiency ratings show up in the form of "80 plus" from silver to platinum and some even higher). The psu supplies power to all your other components as the name implies and if there is so be a short it can kill any if in the worst case all your components rendering all your hard work and money spent a waist as there is very little you can do to fix them after a short.
Some very highly praised PSU brands include Corsair, EVGA, Antec, CoolerMaster, Silverstone (just to name a few)
An expensive GPU or graphics card is looked down on by some because of a Price/Performance ratio where in most cases a $500 GPU will out perform a $300 GPU but to a lesser degree than a $50 GPU compared to that $300 one
Think of it like counting where it starts easy then gets progressively harder (1, 2, 3, 4.. 5.. 6... 7.... 8....... 9........ 10) In most cases the $350 range of GPUs seem to have the highest Price to Performance ratio although it is never a bad idea to go higher if your budget allows
The 500b and 600b units (and w1) are made as cheap as possible and feature tackky chinese caps and components and these units do not even stay in there %80 efficiency rating (if i was evga ied be ashamed to have my name on these oem units)
Try something like this if you have any questions and/or concerns feel free to ask.
Build One: http://pcpartpicker.com/p/s2ghpg
What about fx-8320? It's a bit less expensive and it can be overclocked to same speeds as 8350 and it would give you more money for your PSU for example.
Thats a really solid build! I appreciate it, is an SSD a necessity or should money be put towards a bugger hard drive?
Well with $1000 you could go with a skylake i5.
http://pcpartpicker.com/p/YCB9zy
$10 over. Meh.
I like the sound of that.. What's the best intel GPU for dollar/performance thats comparable?!
Oh, wait, hang on, streaming? We need some xeon up in this thing.
Heres my personal pick for a build
The 8 core 8320 can be easily overclocked with this asus motherboard to meet the same specifications as the 8350 and even a bit better. Also the 8 cores are pretty good to stream with, very smooth frame rates. This R9 390 seems like an obvious choice with your budget and I'd coupple that with a nice 27" 1440p monitor and you my friend have a really nice gaming experience.
As for ram even in this day and age i don't see anyone ever using more than 8gb even while streaming, and ram speeds isn't something you should be worried about unless you have an apu which is invalid with your budget
http://pcpartpicker.com/p/XXXZyc
I completely forgot about initials new processors.. Would you take an ASUS motherboard over an MSI motherboard?
What's a card for around $400-$500 that will be the best value in your opinion? Would you stick with the Sapphire you lined?
dont go for the gpu that is intergrated inside of the intel CPU they are not up for it.
here is my build and hope you can spend the extra on your build if its at a $1000 http://pcpartpicker.com/p/8qLYGX
@cooperman the 500b and the 600B are better than the CX Series since they are rated at Tier 3 and the CX Series are rated at a Tier 4. http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
Indeed I updated that post for my reasoning why
EVGA GTX 980 SC ACX 2.0 on sale for $499 on amazon
No SSD's aren't necessary but they're worth it because of there speed. 1TB should be plenty of room for games and other stuff, put your OS on the SSD. Also the performance increase of Skylake isn't that great so I would stick with the Haswell Refresh as used in my build. Also again AMD processors will bottleneck modern GPU's you are much better off going with an Intel at this time.
If you'd like you can change that 500gb ssd for a 250gb one and maybe get a cheaper case and you can fit the gtx 980 in there but In my opinion the build I suggested is probably the most satisfying and the 980 isn't much better than the r9 390 plus the sapphire card I chose has some of the best cooling for overclocking potential.
