First sound card
I've usually never gotten a sound card before preferring to spend the cash on a better video card and stick with the onboard audio but I've got some extra cash lying around so I was wondering about which sound card would you guys recommend?
A little info about myself- when I listen to music I usually turn the bass down so hear the vocals and instruments better and in games I'd like to be able to hear every tiny detail. Also I'm using a pair of shure srh840 and my budget is around $200 usd
p.s. I have a mpower max mobo right now with a 7970 lightning gpu, I was thinking of buying a 2nd card for crossfire. The 2 cards would be x8 x8 but if I put in the sound card would the go to x8 x4 x4?
http://www.amazon.com/Xonar-Phoebus-Gaming-Soundcard-Sound/dp/B007ZT1Q3E/ref=sr_1_5?ie=UTF8&qid=1379189215&sr=8-5&keywords=asus+xonar
If you want the best this is the way to go and for your motherboard I think your board has a pci 1x on the top so just put the sound card there
anything in the asus xonar line is going to be good for gaming and good for music as well
one of these would be good too
http://www.amazon.com/PCI-Express-Channel-XONAR_DX-XD-90-YAA060-1UAN00Z/dp/B0017DJXG6/ref=sr_1_6?ie=UTF8&qid=1379189405&sr=8-6&keywords=asus+xonar
I was looking at that card and also the creative SoundBlaster zrx http://www.newegg.com/Product/Product.aspx?Item=N82E16829102050
On newegg right now you get a free headset with it and if I put it in the first x1 slot the 2 gpus will still run in x8 x8 right? What if I put it in any of the other x1 slots. The mobo is configured in x1-x16-x1-x1-x16-x1-x16.
ya they should still run in 8x 8x if you have crossfire going and the sound card in the 1x slot.  I have heard that asus has better drivers and software then creative so I would get the asus phebus or the essence
Oh ok thanks for the help. Doing further research I think I'm gonna pick up a xonar essence stx.
