First small form factor PC
Hey, i'm considering building my first M-atx or Micro ITX computer. I'm gonna be using it for gaming. Now i live in Denmark, and everything is super expensive here, what you can get in the US for 1100$ i need at least 1300 to get, THe budget is 1377, that is the equivilant to 7500 Danish kroner, now remember, it's probely easier to aim for 900 or 1000-ish.
It has to include a monitor, and a keyboard, and no optical drive is needed, Also windows 8 or 8.1 is in the budget as well.
This is what i have made up, dunno if it's good though.
Benq GL2250
actic cooling freezer 13 co
1 WD blue 1 tb
1 Crucial M500 120 gb
1 X 8gb  single module corsair vengeance ram (low profile)
Corsair cx600 v2
I5-4670k
MSI H87I AC
1 MSI gtx 660 gaming.
Windows 8.1 OEM
If you wanna try and find the parts on a danish website, similar to partpicker here's a link http://www.edbpriser.dk/
ALso, the prices are similar to the UK ones, but still a bit more expensive
Thanks for the help
-FerverdCookie27
try to see the asus and asrock mobo
consider on an amd apu and a amd vga
aio water cooling for the cpu
2 sticks of ram, in case one of the 2 stops working
samsung evo ssd, good performance for a cheaper price
Yeah, none of that is actually worth it here in Denmark, everything's so much more expensive, than what i've already chosen.
Also i forgot to say, it needs to have built in WIFI, which is why i chose the mobo i did.
