So, this is my first real gaming build, i have always skimped a scrounged parts together for my pc's and have finally saved enough! so figured i would post and get some feedback and thoughts to this build gpu has been my main headache with so many reviews and models lol (current system only has a pny gt 610 in it)
but here is my parts picker link would appreciate your ideas and thoughts
The CPU seems to be lacking, I'm sure it would be fine but seems weird to spend more than the CPU itself just to cool it. this is what id go with http://pcpartpicker.com/p/6ynNZL
swapped out the SSD, 280 for the 285, the CPU for an 8 core without water cooling, also used diff mobo.
Eh, the R9 285 doesn't perform too much better than an R9 280, and is more expensive.
http://pcpartpicker.com/p/psP9vK
UD3P uses a digital 8+2 power delivery system, and therefore is much better suited for the 8320's high current draw.
Back down to a R9 280, for the reason stated above.
Cheaper case. You really don't need a full ATX case. Of course, this is personal preference.
Better quality power supply. 750w is also pretty overkill, and I would rather sell off the R9 280 and grab a high end GPU to replace it if OP were to upgrade.
Definitely understandable, was just trying to get the basics of what he already had and improve, from my understanding i thought overall the 285 did outperform the 280 at only 10$ more(including MIR).
In a 700$ build, which is still a pretty tight budget to build a capable gaming machine, I really would not waste money on watercooling and an expensive case. The PSU is also a bit overkill with 850W.
Here's a different approach, pretty much in the same price range as your initial build, but more powerful. If you want to save a couple of bucks, you can still go back to the 280 or 285, but I went with an R9 290 and an intel CPU, no fancy cooling, high quality PSU and such. Enjoy!
Yeah, cheaper mobo, stock cooler, cheaper PSU and case, simpler HDD. You can shave of some more dollars from my build. Stupid mail-in rebates. But I think we can agree that the i5 / R9 290 combo is going to kick some ass in that price range.
I find picking mobos in that range pretty hard. Over here in Europe the ASUS B85 Pro Gamer would be my goto part, but in the US that one is just sooo expensive for some reason.
