First real build
Hi everyone.
I understand that you most likely get a lot of people asking the same question about what hardware they should use in their first build. Regretfully I am going to add my self to that list of people. I have been educating myself as best I can in all things tech but with it being such a diverse and complex subject I have decided to turn to you guys.
I will start buy telling you what i will need the computer for and if you could use your far superior knowledge to recommend (flattery hopefully will help).
I am going to be using the computer for work (basic stuff such as spreadsheets and PDFs), some spread betting (real time stock charts), playing around with fruity loops (music sampling software), Website building (adobe CS 5, something I am trying to teach myself), editing for YouTube (mainly my girlfriend doing this as she has a channel) and last but not least gaming (nothing too heavy though).
Ok now for the main reason i need you guys (otherwise I would use one of Logan's recommendations i.e. the 1500 dollar editing rig). I need to run 6 to 8 screens.
I don't have a budget, cheaper is better but not to the point where things become a labour of love (i.e. editing).
I live in the UK but also spend about 4-5 months of the year in Amsterdam for work so could get the parts from either the UK or mainland Europe.
Many thanks
Paul
PS Love the videos and site Logan and team.
What is your budget? I get the feeling that if I build a £10k machine you will suddently have a budget.
you would be right. I think upto 4k would be the max I could go.
Thank you.
Ok I decided to try to put together something cheap to act as a benchmark for price etc
http://pcpartpicker.com/uk/p/xetB
please note am only just getting into this so any sugestions would be appricated
You are missing some Hdd but it looks really good.
Do you mind paying a bit more for a better cooler?
Thank you
I am happy to pay for a better cooler. Any suggestions?
I have a 1tb seagate spare so i will just use that.
DO NOT SLI a 660 or 660Ti
the 192 bit memory bus will negate almost all advantages of SLI you get
Ok, thanks.
What video cards would you recommend instead.
if you want to go Nvidia, 670
for the same price as 2 660s you could get a 7970 though and a single powerful card is always better than SLI/Crossfire
http://pcpartpicker.com/uk/p/xfpA
This would probably work well. :)
If the computer is going to be used for editing it would be a smart choice to go with a nvidia GPU. This being because they have cuda cores; and that increases the editing and rendering performance drastically.
Tell me if you were looking or something cheaper and i'll see what i can do :3
useful to know but i want to run 6 monitors. I guess I could use the eyefinity 6 model but I have been told 2 cards preform better.
Thanks, this looks very good. The price range is fine.
thanks alot
Glad i could help :)
Also if you're planning on upgrading to more than 16GB of ram in the future you're gonna have to get windows 7 professional or ultimate i think it was. Windows Home premium only supports up to 16GB of ram.
If money really isn't a problem, then I would go for one of these builds:
AMD: http://pcpartpicker.com/p/xgwN
Intel: http://pcpartpicker.com/p/xgwu
The sound card is optional, and by removing it will lower the price by about $200, but here is my configuration for you: http://pcpartpicker.com/p/xgLD
There are 7x140mm fans for a reason - 3x for the case and 4x for the radiator on the NZXT Kraken x60. This build would dominate everything for the next 5 years (64GB of DDR3 2400 RAM...). If you ever needed to, you could just 3xSLI the 4GB EVGA gtx 680 for super power. The reason I didn't use an EVGA gtx 690 is due to the fact that each card is limited by the 2GB of GDDR5 and won't support 6 monitors. This build is just over $4000, so I hope that woulnd't be a problem. Overall, this computer would murder all other computers for at least the next 4 years. Enjoy!
-Brennan Riddell
Thanks for this, upto 4k is fine cause I can write it off as a business expense (any more and they might start asking questions).
At the bottom of the build it sayst there are some compatibility issues.
  • Intel Core i7-3930K 3.2GHz 6-Core Processor and G.Skill Trident X Series 32GB (4 x 8GB) DDR3-2400 Memory are not compatible.
  • G.Skill Trident X Series 32GB (4 x 8GB) DDR3-2400 Memory operating voltage of 1.65V exceeds Intel Sandy Bridge-E CPU recommended maximum of 1.5V.
Will this be an issue that can be solved?
Thanks. Which of these builds would you prefer.
Thats good to know, I will look into which one supports more than 16GB of ram as it will be one of the first upgrade i would do
Cheers
Oh! I forgot that 2400 doesn't work on Sandy Bridge-E! The voltages are off. Here - I changed it to a slightly lower frequency, and added a Blu-Ray reader/writer: http://pcpartpicker.com/p/xhqL
It is a bit cheaper with the lower frequency memory, which put an optical drive, albeit, they are useless, this is the most useful one you could have: BluRay is awesome!
Cheers,
-Brennan Riddell
Don't use any lower frequency memory - the 2133 should be the minimum. DDR4 will go well over 3000mHz, and if you don't get some of the faster memory now, your computer wouldn't be competitive. When Ivy Bridge-E comes out, which you might want to wait for, you could get 2400mHz memory instead, adding a bit more longevity to the build, but DDR3 2133 is stil insanely fast. I have 16GB of that G.SKILL Trident X 2400 in my Z77 setup, and it is blazing fast. I never run out of memory, but for editing and to simply take advantage of the features of the motherboard, 64GB is best. Obviously, nothing uses that much memory, but you have freedom to run server(s) on it, and with a 6 core processor, you could host servers without a noticable change in performance. Happy building!
Cheers,
Brennan Riddell
