First Proper PC Build, Need help with gpu
ok so i have finally decided that i might put the money down on a built pc to play games mostly along with some web browsing and word processing.
so here is the link to the current build i have in my cart with exception of the gpu. as of right now i have a am2+ build that has a geforce 9500gt with 1gb of ram, but i dont even know where to start as far as a new card would go. so................ if i could some input from you guys and some thoughts on what i have.
Thanks,
Boneskid1
 EDIT: i forgot to add a budget i would for sure want to spend less than 200 and if i have to go more i would, but it would have to have a large benefit
EDIT 2: here is the paste from the cart
Ram:                    Crucial Ballistix Sport 8GB DDR3-1600 PC3-12800) C SKU: 211334          $44.99
Optical Drive:          LG 24x Super Multi Internal SATA DVDRW DL Drive -  SKU: 251900          $15.99
 CPU:                    Intel Core i5 3570K 3.4GHz LGA 1155 Processor  SKU: 425470  $189.99
Mobo:                   Biostar H77MU3 LGA 1155 mATX Intel Motherboard   SKU: 033613     $19.99 / $9.99 after Rebate
 HDD:                    Western Digital Caviar Blue 500GB 7,200 RPM SATA 6  SKU: 212894 $64.99
 PSU:                    Corsair CX Series CX600M 600 Watt ATX Modular Power  SKU: 189845     $79.99 /$59.99
after Rebate
 Case:                   Thermaltake V3 Black Edition ATX Mid Tower Computer SKU: 497818     $34.99/ $19.99 after Rebate
so the total with all of that before any rebates or anything is...............$489.98  USD
That's a link to a cart....only you will see the build you posted because it's in your cookies. Use PCPartpicker or a newegg list
ah ok my bad i forgot about that,
i am considering getting a cheeper dual core like the i3 or the pentium, but if i get this biostar board it is 10 bucks with anything more powerfulll than the pentium.
I'm confused by your posting. If you are looking for a cheap graphics card:
http://pcpartpicker.com/part/zotac-video-card-zt6090110m
basically i am trying to build a decent budget pc to game with and stay on the intel platform so with the parts in the above post the last thing i need to get is a video/grapics card/gpu. that is what i am asking asistance for as i dont even know where to start.
Uhh wtf? $20 motherboard? Or am I reading something wrong?
he says 20 dollars but its 80 on newegg
it is only 20 because it is bundle with the i3 to i7 cpu
