First PC
Hi im new to the site and anything pc related and i would like some help.
heres what i have so far my budget is around $1000
CPU: AMD FX 8350 black edition
refurbished WD Hard drive 2TB 7200 RMP 64mb cache
Case: Fractal Design core 1000 usb 3
bought those three really cheap but i dont what to do next, need help thanks!
how much of that 1k have you spent so far on your parts? or do you have 1k left? also what sort of usage? what country? do you need peripherals like screens? mouse? keyboard?
You are going to need to send the pc case back as there are no matx mobos that are any good for a 8 core cpu in fact i'd send all that back and buy this...
http://pcpartpicker.com/p/zF32Jx
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($209.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard ($99.99 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory ($68.42 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($86.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($39.10 @ SuperBiiz)
Video Card: MSI Radeon R9 390 8GB Video Card ($294.98 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($64.99 @ NCIX US)
Total: $914.44
ive spent some buying those 3 parts so around $700ish left i dont need peripherals my old ones still work also i live in the US, by usage do you mean what im using the pc for? becuase its mostly for gaming preferably 1080p thanks for reply
I'm set on the CPU and HDD as i bought those cheaper before maybe the case as i really thinks its too small
http://pcpartpicker.com/p/TMrxpg
Base Total: $677.69
Promo Discounts: -$21.25
Mail-in Rebates: -$50.00
Total: $606.44
case will work fine, but you will have to remove one of the drive bays. you can mount your drives higher where the 5 in bays are. got a beefy psu so you can upgrade later. you could go a 390x or a fury but for 1080p you dont really need to. i have that EXACT cpu fan and it works great, but you could get a better noctua with dual fans if you want to really overclock to the limit.
that seems good also would an old video card work too like r9 270-290 and still get a decent fps on games like bioshock infinite?
http://pcpartpicker.com/p/b3Mnxr
Motherboard: ASRock 990FX Killer ATX AM3+ Motherboard ($99.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($77.99 @ Amazon)
Case: Fractal Design Define R4 Blackout ATX Mid Tower Case ($69.99 @ Newegg)
Total: $696.35
No thats a fire hazard and the card and cpu cooling unit whont fit in a core 1000
270-290 would be fine with bioshock infinite.
http://www.bit-tech.net/hardware/graphics/2013/11/05/amd-radeon-r9-290-review/5
@cooper it'll fit if you remove the drive cage or the middle one. 350 mm wide and only 300 mm gpu.
Return the case and here is my recommendation.
http://pcpartpicker.com/p/rjCmwP
http://pcpartpicker.com/p/FvcCHx
$1000 is a bit to play with considering you have the processor and drive If you drop the 390X you can squeeze in a Fury. Whether or not it's worth it is up to you
That is not a core 1000.....
THIS IS
ok. same solution still works. remove/alter drive cage and you have enough room.
That's not a knife... This is a knife
Wrong thread...
thanks for the reply guys also sadly i bought the case a long time ago and it was pretty cheap so i dont think i can return it anymore also for the gpu would it be ok to downgrade it to r9 290 and still play a game like bioshock decently?
there is no harddrive cage the harddrive/ssd gets bolted to the bar trust me none of that will fit and it has very poor airflow it will be a hot box.
yeah i think the case is the problem its too compact, i can replace it with another since i got it cheap but still that gpu though, what do you guys think about replacing it with r9 290?
im new to this and ill be mainly using the PC to play bioshock games and DotA 2 or CS
A 390 is just a 290 with more vram if you can find one cheap go for it
