So I was putting together my first PC and thought some feed back would be a good idea. It will be mostly used for gaming. I was going to go for a Radeon 7950 or a r9 280x but the prices are way to inflated right now so I went with a gtx 760. http://pcpartpicker.com/user/achocolatecow/saved/3hvV
Is there a specific reason you went with the AMD 8350? If you pricematch Microcenter's price for the i5-4670k it will be cheaper than the 8350, and you can get a motherboard that has built-in wifi.
Honestly I don't think you *need* a Sabertooth 990fx if you're only running one 760, and with the money you save with a better priced for your needs motherboard you could get a gtx 770
There isn't really a reason why I want the 8350 i guess I just want to go AMD. Later on I was thinking of over clocking and plus the warranty of the Sabertooth has me sold on that.
I'm saying there's some great 990FX motherboards that don't cost as much as the Sabertooth 990FX. Honestly running one card you don't really need a board with that many features. The Asus M5A99FX Pro for 60$ less will provide just as good overclocking as the Sabertooth 990FX but is only lacking a few features of the 990FX that you probably wouldn't use anyway. All I'm saying is look into where you're putting your money.
