I'm building a new gaming pc soon, and I didn't want to mess it up, so I thought I would come to you guys. Here it is: http://pcpartpicker.com/p/z36y
Budget is $860 (USD) and I'm going to use it for internet and gaming.
faster ram, better CPU arch, better mobo, and faster GPU
Plus a better PSU
But it got lost in the flood of posts, I wasn't getting clear answers :/
well its not a better PSU but then again he doesn't need more than 530w for his system, mine also comes with a heatsink but lacks a ODD
Will the 6200 not do? I don't think I want a 7970, as Logan mentioned that they get very hot.
6200 is on faildozer arch, 6300 is Verhersa
and that isn't a GHz edition, so they don't get as hot, its a non reference cooler as well, if its still too hot then underclock, it underclocked will be faster than stock 7950
Ok. Thanks
If you want to see the posts you've commented on or made, go to FORUM then click the "My Stuff" tab. They should all be there. If you want to see the posts with the latest comments, click Updated/commented date, wait for it to load, then click it again.
Well, I'd trust Rosewill more then CoolMax. Rosewill Greens are pretty decent
I still wanna stick to the 7950 because I don't wanna run into any issues whatsoever. So, will this system work?
