First PC help (PARTS)
I need help knowing if the following parts will be good enough to play games like bf4 on Medium to high graphics while maintaining a decent fps rate,
GA-EP45-UD3 Motherboard
Intel Core2 Quad Q6700 2.66ghz processor
G.SKILL DDR2 2GB sticks X2
Need help deciding which graphics card to get but got suggested a radeon 7750 ddr5 graphics card
Stock heat sink
Thanks
About the best graphics card that WONT be bottle necked by that outdated quad core would be the radeon 7770. From what I've been seeing of BF4 is that even some of these new considerably more powerful systems are being bogged down by it. I see no future with that old set up being able to run BF4 even on medium settings and be able to maintain a playable 30fps. You need a new rig.
If you really wanted to try to push that machine a little longer, you could try getting a Radeon 7750 or 7770 and grab yourself a nicer Heatsink for your processor and overclock it to 3ghz. Your motherboard is overclocking capable, atleast moderately so. Getting that processor up to the 3ghz mark should be a safe and stable overclock and give that machine a bit more power. But I'm still not convinced that it would be a powerful enough rig to push through a playable round of bf4.
to be honest i don't know why i wrote BF4 i was convinced it would run it with a decent graphics card but will it at least run games like Skyrim,World of warcraft and LoL ?
you could just play Runescape lol...
well that CPU is quite outdated being 6 years old, and should only give you a third of the performance of a 3770. However, a 3770 is a great processor that will run all modern games on Ultra.
I'm guessing that you have some parts lying around  or will get the for dirt cheap, and that you are looking to buy some components.
What you will be looking to do in the future is changing Mobo and cpu, get a couple of more sticks of RAM. What do you have that we can play around with?
Perhaps spend a little more on the GPU now and having it bottleneck a bit until you upgrade the mobo/cpu/ram in a year or so?
As if that rig can play games, it will. Perhaps not great and perhaps not the latest titles but it should be able to play many games on lower graphics settings.
Yeah those parts were given to me for free from a friend that wanted me to get into pc gaming as I'm not getting 'Next-gen' consoles.
He didn't recommend them if i was going to play modern games so now I'm considering using Syndicates latest 650$ build.
Ive got a older rig Running a Q6600 overclocked at 3ghz with a gtx 560 and 8gb of ram. I can load up Bioshock Infinite on it or something and see how it runs that. If my rig can play that decently, you should be able to push some life into the Q6700 and see if PC gaming really is for you atleast. atleast then all your paying into it is for a graphics card.
http://pcpartpicker.com/p/2j1Es
if i can play fc3 @ ultra w/ a celeron 2gb ddr3 and a gtx 280
than a 7790, 8gb ddr3, new mobo, new hdd, and 600w psu should play games fairly decently
As Nitro said i first should see if PC gaming is for me first ill just buy a Gfx card and extra ram for now then maybe later ill invest in a new rig.
Cheers though and I'm liking the PC community! :D
If you wanted me to push my older rig with some games I would be glad to.
That would be awesome!
Since this machine is destined to be sold soon I'm not going to link my main steam. So I'm going to download Planetside 2 which is a very graphics intensive FPS and push the graphics as high as I can and then drop right into a full blown battle and see whats playable. I've got it downloading now so I'll post back in tomorrow when I get a chance to play it.
Much appreciated  even though i highly doubt it will run Planetside 2 very well
Ok, believe it or not its very much playable. I overclocked my GPU to 950mhz just to make it a little more fair to the newer cards and threw the graphics to ultra. I was getting around 34-40fps in the feild and dropped to around 22-27 in a decent battle. Then I dropped it down to High only and I didn't see it fall under 30fps at all. I was getting 55-60 fps in the field and 32-43fps in a good battle. Playing it on Medium settings was perfect for my older GPU but im sure if I fiddled with it more I could push those settings higher. So It looks as though if you get some more ram, and a nice GPU and maybe a slight overclock on that processor like I suggested. Games like Planetside 2 are within your options :D
The PC is dated, but it'll handle some things.
Big AAA's will bog down, especially with 4GBs of DDR2. Processor should handle them fine though. You'll get occassional issues, but mostly games are entirely down to GPU. Rarely do we see a bottle neck in CPUs until we go way, way back. We had Skyrim running on a Pentium 4 with a 7800GTX or whatever it was from 2005. Low graphics, 720p, but 20-30fps...
Depending on your approach, by a mid range, £175-200 GPU. Play some games. If load times and clear CPU usage is peaking (run a CPU/RAM/HDD monitor) then consider upgrading the core internals. But you already have a GPU so it wont be that bad. :D
But a Q6700 is only a bit slower for general tasks than my i7 920, which still flies today with no need to upgrade. The 4GB's of DDR2 is gonna hold you back though and you'll need a new mobo at least for DDR3 support. If you can find 8GBs of DDR2 on ebay for a few pounds, maybe take a punt. Are there 2 or 4 slots in the system? If not, take a punt on a socket 775 mobo (iirc anyway) that accepts DDR3 ram. The fleabay could get you a whole gaming rig for £200!
His Mobo has 4 dimm slots and supports a max of 16gb of ddr2. He should be able to boost it up to 8gb easily. I just tested a Similar rig for him with a Q6600 oc to 3ghz with 8gb ddr2 ram and a gtx560. Planetside 2 is playable on High settings, better on medium but still. With the right upgrades and a nice GPU it should be a decent, be it, Older rig.
Awesome! now what GPU is recommended ?
How much are you looking to spend overall? you still need 4gigs more ram and a powersupply too right? also what is the speed on the ram you currently have? Also do you have a Case?
I'm looking to spend 200-250$ and no i don't have a case and power supply. And the speed of my ram is 1000mhz its a 2x2 gigabyte kit so i'm not sure if its 1000mhz each or together..
