Ok, well i know that this topic has probably been brought up more times than can be counted but i am bringing up again. I was wonder if you guys could give any feed back on my part choices and if you think i should change any of them. Also i do not plan on overclocking my machine until i get more confident with the workings of it.
First:
CPU: I Chose the Intel core i5-4690k 3.5GHz Quad-Core Processor for the mother board. This just seemed like a good processor, i might be wrong i have no clue.
CPU Cooler: I Chose the Noctua NH-U12S 55.0 CFM CPU Cooler. Please Give feedback on this i really haven't even heard of this cooler.
Thermal Compound: Arctic Silber 5 High-Density Polysynthetic Silver. This Seemed to one of the higher rated ones and again i might be wrong.
MotherBoard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard. I heard MSI is good for gaming.
Memory/Ram: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory. I have seen ripjaws used on a few builds on youtube.
Storage: Samsung 850 EVO-Series 120GB 2.5" SSD.
and Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive.
GPU: MSI GeForce GTX 970 4GB Twin Frozr V Video Card.
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case.
Power: Corsair Builder 600 80+ Bronze Certified ATX Power Supply.
Optical Drive: Samsung SH-224DB/BEB DVD/CD Writer.
Operating System: Microsoft Windows 8.1 (OEM) (64-bit).
Monitor: Acer G246HLAbd 60Hz 24.0" Monitor
Keyboard and Mouse: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/ Optical Mouse.
ok that's what I have put so far. I ran it through pc part picker and they say there is no compatibility issues but they could be wrong. I was wonder if i might be putting to much into one part, not enough into another, or if there will be any bottlenecking in this build.
Following PC Part Picker they say without rebates and promo discounts this build would be $1432.79.
Again i will ask if this is a good build or if i should change some aspect of this. Also the reason i added the Keyboard, mouse, and Monitor is because of the fact that i really don't own a good computer and have really only console gamed. The best monitor i have is probably the first one that was capable of using an hdmi cable.
Feedback is very needed in this topic.
