First PC Build:
I just want to make sure if everything checks out ok. Comments criticisms suggestions welcome.
EVGA Z97 FTW LGA1150 ATX 4 DIMM Dual-Channel DDR3 2666MHz Motherboard
EVGA GeForce GTX 760 Dual 4GB w/ EVGA ACX Cooling
WD Green 2 TB Desktop Hard Drive: 3.5 Inch
EVGA 600B 80PLUS Bronze Certified ATX12V/EPS12V Active PFC 600W Power Supply
Kingston Technology 2133MHz DDR3 Non-ECC CL11 DIMM XMP 16 DDR3 2133 Kingston HyperX Predator 16GB Kit
Intel Core i7-4790K Processor
What will you be using the PC for and what's your budget?
Sorry the PC will be used for gaming, Preferably running higher end games at a recommended setting. Budget is around 1100 dollars.
Id like to add,
Why no SSD man!
sandisk Ultra 128 gb for the OS atleast.
my boot time on ssd is like 10 seconds man! Win 7 ultimate
Like Pruikki said you should realy get a SSD.
You also just need 8gig of ram if your just gaming.
http://pcpartpicker.com/p/gDTvYJ
This is what i would build.
Faster Gpu,with more and faster memory, and a SSD.
I havent included a case as you havent one in you original Post.
  1. instead of dual 4gb 760's you should just get a 290x or gtx 980 (don't really trust Nvidia right now would go with the 290x) not all games support sli, and additionally sli can cause some strange issues with lower end cards.
  2. ram of 2133 mhz will require overclocking the ram controller on your cpu with only a 1-2% benefit to gaming over 1600 mhz while risking damage to your memory controller from overclocking it, of all the things to overclock this is not worth it stick to 1600 mhz
  3. you only need 8 gigs of ram this will accommodate running a game with several things in the background
  4. get an ssd, i'm partial to crucial or samsung ssds
  5. since this is a gaming only pc don't get a WD green get a Black or Blue.
  6. Get and i5 not an i7 a gaming build has no need for hyperthreading.
You should go for something like this.
http://pcpartpicker.com/p/FHDrLk
Thanks for the help. Really means a lot. Gonna be making a few changes.
